smooth4lyfe
Trusted Member
I had this EXACT same problem but I figured out what was causing it.
I had an app called "Audio Manager Pro", which was causing my ringtone to divert back to the original. I just had to change the settings on that app and problem fixed!
If its happening to you, it could be some app that controls your sounds that is causing it.
