Well... from my perspective in order of importance.
1) Fit/comfort - if the damn things don't fit right, hurt after wearing for a few minutes, fall out easy... that renders them more useless than most anything else...
2) Sound quality - I've had a bunch of ear buds and if the sound quality is trash, or the volume levels are junk... again... you'll never want to use them and look for a replacement
3) listening time - if the best fitting and sounding buds only last 45 minutes... meh...
As for noise canceling... most in-ear buds have some level of passive noise cancellation because they're stuffed in your ear. Now, active noise cancellation is the most ideal BUT... buds that have it are often crazy expensive and it will have an impact on charge performance since its more stuff the buds have to do. Plus, it will add a little bit of mass and size... Provided they don't transfer a ton of wind noise, I wouldn't concern myself with active NC unless you positively have to have it.
08-25-2016 09:40 AM
