1. Derek Danforth's Avatar
    I have a samsung mini wireless charger. My note 7 doesn't seem to want to stay charging unless im using a fast charger adapter. Does anyome think that will be an issue for the charger?
    Posted via my Note 7 (Black Onyx)
    08-25-2016 01:49 PM
  2. SpookDroid's Avatar
    The wireless charger won't actually use the quick charging feature of the wired one, so it'll just 'default' to a normal 2A charger. You should be using at least that rating on your wireless charger or it might not have enough power to output, especially if it's not a 'fast' wireless one.
    08-25-2016 01:54 PM
  3. Derek Danforth's Avatar
    Yeah i knew it wouldn't charge faster I just thought it was odd the included charger wasn't powering it. Once I posted this question it started working fine. Thanks for responding.
    08-25-2016 02:07 PM
  4. SpookDroid's Avatar
    Check the position, too... with a mini-charger it might be harder to get into the 'sweet spot' under the phone.
    08-25-2016 06:01 PM
  1. Replies: 7
    Last Post: 10-08-2016, 11:28 PM
  2. How to solve Note 5 battery life issues
    Last Post: 08-30-2016, 04:07 PM
  3. Lock screen security issues.
    By durandetto in forum Samsung Galaxy Note 7
    Last Post: 08-27-2016, 02:46 PM
  4. Audio issue when shooting video
    By gdigenis in forum Samsung Galaxy Note 7
    Last Post: 08-25-2016, 09:06 PM
  5. htc one mini wont turn on
    Last Post: 08-25-2016, 01:50 PM
