1. Makad's Avatar
    Information for those who have GM vehicles with the wireless charging pad.
    After I got my new Note 7 I tested it to see if it would work as my Note 4 did with the wireless charging pad in my 16 Escalade. It didn't, I was disappointed. I found the solution from the S7 and S7 edge forums. The solution is to have the bottom of you Note 7 hang over the bottom of the wireless charging pad area, about a quarter inch and it will do the wireless charge, even with the phone in a Spigen case.
    08-26-2016 11:34 AM
  2. rdickert's Avatar
    I have a 2015 Caddy ATS with the wireless charging in the bay behind the AC controls - it works perfectly with the S7 but anything bigger (like the S7 Edge or any of the Notes) is too large and won't fit or function - sad
    08-26-2016 11:52 AM
  1. How to add os in my htc one m7?????
    By patel 1208_shiv in forum HTC One M7
    Last Post: 08-26-2016, 11:39 AM
  2. Replies: 1
    Last Post: 08-26-2016, 10:15 AM
  3. "USB for Charging" notification
    Last Post: 08-26-2016, 09:37 AM
  4. haptic feedback in power saving mode?
    By weesy in forum Samsung Galaxy Note 7
    Last Post: 08-26-2016, 08:36 AM
