1. ManofmanyStangs's Avatar
    I have looked everywhere and can't get the phone to vibrate more than once on incoming call. While it is in my pocket. If it is in my hand it vibrates more than once.
    Thanks
    08-26-2016 02:56 PM
  2. ManofmanyStangs's Avatar
    Anyone know a fix for this?
    09-09-2016 09:18 PM
  3. toenail_flicker's Avatar
    Have you tried a different ringtone?
    09-09-2016 09:59 PM
  4. ELAkid's Avatar
    Thanks
    Do you mean the vibration pattern when receiving a call?
    09-09-2016 10:13 PM
  5. ManofmanyStangs's Avatar
    I am using vibration no sound. It will only vibrate 1 time then stop, if it is in my pocket.
    09-10-2016 05:20 AM
  6. ManofmanyStangs's Avatar
    No not really no matter which vibration pattern I use it will only vibrate once.
    09-10-2016 05:21 AM
  7. toenail_flicker's Avatar
    What I meant, and granted, it may not make a difference, is have you selected another tone that rings or vibrates more than once, then turn the ring off and see if it vibrates more than once with ring pattern that rings more than once? Have you tried that?
    Also, it would be helpful it you explained what you have tried.
    09-10-2016 08:18 AM
  8. jstevensdk7's Avatar
    Having the same issue, did you ever find a work around? This if intended by design as a feature, is really stupid.
    09-26-2016 02:18 PM
  9. French's Avatar
    Do you have "keep screen turned off" on? (prevent screen from turning on accidentally while the phone is in a dark place such as a pocket or bag)
    It's in the display menu. If it's turned on, try turning it off and testing it.
    09-26-2016 02:20 PM
  1. how to make your screen rotate?
    Last Post: 09-12-2016, 11:45 PM
  2. How can I hang up calls on my Alcatel android?
    Last Post: 08-26-2016, 03:20 PM
  3. Replies: 1
    Last Post: 08-26-2016, 03:08 PM
  4. Replies: 1
    Last Post: 08-26-2016, 02:46 PM
  5. What is the ICC ID # of my phone?
    Last Post: 08-26-2016, 01:51 PM
