08-28-2016 10:27 AM
39 12
tools
  1. Kelly Kearns's Avatar
    STILL NEED not verizon sim installed in non verizon carrier message gone.
    To me that sounds like a Verizon issue that something is still tied to Verizon.
    ETA: I've sent a message to someone to see if they might know more about this.
    08-27-2016 04:25 PM
  2. anon(9780053)'s Avatar
    Been thru 4 devices, 2 contracts etf fees and now tmobile. I could own a car by now.tyvm
    08-27-2016 04:46 PM
  3. anon(9780053)'s Avatar
    Btw guys,,,,,,,,,,,,,any clue of this new ghost; it be sad if no ever ota updates as in nougat 7;dint think of that.honeymoon is over and must divorce verizon wireless and need to know if ATT will take me-screenshot_20160827-173947.jpg
    08-27-2016 04:49 PM
  4. Kelly Kearns's Avatar
    You won't be able to get OTA with a Verizon phone on TMO, that is one of the good reasons for having that carrier's phone.
    You will have to use Kies or Smart Switch on your computer or go to Best Buy and have it flashed when it is released.
    And it will be the Verizon update.
    08-27-2016 04:52 PM
  5. dpham00's Avatar
    anyone get annoying message says not verizon sim installed in non verizon carrier................how to kill it.
    Long press the notification... It should tell you which app is giving the notification. Then disable the app and the notification should go away.
    08-27-2016 05:03 PM
  6. anon(9780053)'s Avatar
    Called setup wizard . Cant disable. Its greyed out.
    08-27-2016 05:18 PM
  7. Kelly Kearns's Avatar
    Do you have the package disabler app? You should be able to disable it with that app.
    08-27-2016 06:05 PM
  8. Almeuit's Avatar
    As suggested above you may need package disable pro from the app store to disable that app.
    08-27-2016 06:40 PM
  9. Ry's Avatar
    Have all payments been made on the Verizon phone?
    08-27-2016 06:53 PM
  10. dpham00's Avatar
    Yeah pdp should be able to disable it. Although... I would be careful as not exactly sure what that package does... Worse case you may have to do a fdr in the bootloader
    08-27-2016 06:59 PM
  11. anon(9780053)'s Avatar
    YES AND OWE ME TWO LARGE REFUNDS,,,OF COURSE THIER GONNA TRY AND NAIL ME TO THE CROSS. IM DISGUSTED AT THE MILITARIALISTIC behavior there. always never finishing help, just to be transferred like a runaway freight train. THE BONUS IS, THE CALL QUALITY ON TMOBLE BLOWS ME AWAY. VZW WAS LOUSY CALL QUALITY. LIKE DOUBLE VOLUME.
    08-28-2016 09:44 AM
  12. anon(9780053)'s Avatar
    used pdp, now message GONE. WEEEEEEEEEEEEEEEEEEEEEEEEEEE,for now.
    08-28-2016 09:46 AM
  13. Kelly Kearns's Avatar
    I've been very happy with my data speeds and my price on TMO.
    08-28-2016 10:17 AM
  14. dpham00's Avatar
    Glad it worked!
    08-28-2016 10:27 AM
39 12
  1. How to get incoming calls to vibrate phone more than once?
    By ManofmanyStangs in forum Samsung Galaxy Note 7
    Last Post: 09-26-2016, 02:20 PM
  2. how to make your screen rotate?
    Last Post: 09-12-2016, 11:45 PM
  3. Will H1512 work on Verizon in US?
    By millemots in forum Nexus 6P
    Last Post: 08-26-2016, 04:09 PM
  4. Replies: 1
    Last Post: 08-26-2016, 03:08 PM
  5. Replies: 1
    Last Post: 08-26-2016, 02:46 PM
