anyone get annoying message says not verizon sim installed in non verizon carrier................how to kill it.
phone with tax 934.00 why do that. not in this life. im w tmoblile now 50 mo/////no contract or ETF.
STILL NEED not verizon sim installed in non verizon carrier message gone.
Long press the notification... It should tell you which app is giving the notification. Then disable the app and the notification should go away.anyone get annoying message says not verizon sim installed in non verizon carrier................how to kill it.
Called setup wizard . Cant disable. Its greyed out.
Yeah pdp should be able to disable it. Although... I would be careful as not exactly sure what that package does... Worse case you may have to do a fdr in the bootloaderDo you have the package disabler app? You should be able to disable it with that app.
I've been very happy with my data speeds and my price on TMO.YES AND OWE ME TWO LARGE REFUNDS,,,OF COURSE THIER GONNA TRY AND NAIL ME TO THE CROSS. IM DISGUSTED AT THE MILITARIALISTIC behavior there. always never finishing help, just to be transferred like a runaway freight train. THE BONUS IS, THE CALL QUALITY ON TMOBLE BLOWS ME AWAY. VZW WAS LOUSY CALL QUALITY. LIKE DOUBLE VOLUME.
Glad it worked!used pdp, now message GONE. WEEEEEEEEEEEEEEEEEEEEEEEEEEE,for now.
