1. Thurley421's Avatar
    I have had my note 7 since August 19th. I have had the note 2,3,4, and 5. Now i have the 7. I tried to download a pdf file over and over. I get unrecconizable format or drm protected. I need to download the pdf files as they are job aps to bring employees onboard if they qualify. I have never had trouble with the previous note phones. Im sure or hoping it is a simple fix. I do have adobe pdf downloaded. Any help would be great. Overall a great phone but i will have to use my note 5 if there is no fix (i dont want to do that). Thanks in advance for any help.
    08-26-2016 03:16 PM
  2. Almeuit's Avatar
    Select the app "Downloads" to download it first. You can then open it. For some reason if you tell the Write on PDF app to download the file it has a fit and doesn't work.
    08-26-2016 03:25 PM
  1. Samsung S7 vs LG G5 - Hands on/help
    By bboysmax in forum Samsung Galaxy S7
    Last Post: 08-26-2016, 10:18 PM
  2. Replies: 0
    Last Post: 08-26-2016, 12:07 PM
  3. Replies: 1
    Last Post: 08-26-2016, 11:23 AM
  4. help s7edge
    By AC Question in forum Samsung Galaxy S7 edge
    Last Post: 08-26-2016, 06:33 AM
  5. help s7edge
    Last Post: 08-26-2016, 04:44 AM
