No, I don't say the issues don't exist. I do say the lag issue that people have talked about with Samsung TouchWiz, under normal circumstances, is not a horrendous lag. I don't deny lag on a Samsung or any phone.
Samsung Plus is different because it isn't a call center spread out all over the world that is the first contact for general issues on phones.
This group is more specialized, they are located in one building, they are more geared to higher level technical support. Any time I have called Samsung (800 Samsung) I know more about the phones than they do. If I'm calling for help, they have to boot me up a couple of service levels or get someone that generally doesn't handle technical support to call me back.
If it becomes something myself or anyone else doesn't know, we all talk to each other and we get someone to check the issue and step in or give us the info. If it is a Samsung issue that no one knows, I will contact someone at Samsung and find out the answer.
Now with your phone zthey first thing.. Tell me how you set up your Note 7.. As a new device or did you use Smart Switch or did you copy over settings from Google or what?
Give me a chance to see if we can figure out your issue, I'm not going to have you do anything crazy to your phone.
