1. drusum's Avatar
    When I'm charging my phone the red LED light comes on but when it's charged 100% it stays red instead of turning green. Anyone else have this issue?
    08-28-2016 01:20 AM
  2. russel5150's Avatar
    My phone will show it's at 100 percent for prob 5 min before the light turns from red to green. When you look at it on the charger and it shows 100 percent, see if the little lightning bolt is still in the battery icon. If it is the phone is still topping off and the light wont turn green until it has been charged enough the charging turns off.
    keepnitreel and PRGDR like this.
    08-28-2016 03:39 AM
  3. shaw1234's Avatar
    Mine stays red when it hits 100%, but as russel said, it will go green a little while after that.
    08-28-2016 07:41 AM
  4. tinybfk's Avatar
    Same as they said for mine. Stays red for a few minutes after then turns green.
    08-28-2016 12:06 PM
  5. felloffthetruck's Avatar
    Give it enough time and it will turn green.
    08-28-2016 12:10 PM
  6. French's Avatar
    Interesting...I'm using Lightflow and I can't seem to get a green blinking LED to work for a notification (SMS and MMS). It tests just fine...but will not work in real life. Because I'm using Lighflow I know I've probably mucked with the default LED notifications for charging and charged. It will turn red during charging but I haven't seen green for fully charged even after it's sat on the charger for a while.
    08-28-2016 12:25 PM
  7. drusum's Avatar
    I'll try it next charge. Thanks.
    08-28-2016 12:54 PM
  1. TRAIN BREAK [Free][No ads][No IAPs]
    By Giyomu Games in forum Android Games
    Last Post: 11-28-2016, 03:07 PM
  2. No new Nexus this year?
    By iFortWorth in forum Rumored Devices Lounge
    Last Post: 10-05-2016, 05:01 PM
  3. Replies: 2
    Last Post: 08-29-2016, 01:17 AM
  4. Can't conect to home wifi no matter how hard i try.
    Last Post: 08-27-2016, 11:39 PM
  5. Replies: 0
    Last Post: 08-27-2016, 03:53 PM
