09-20-2016 08:26 PM
27 12
  1. Storm1123's Avatar
    Thank you Sandra - Yes, that is the exact problem. I think I found the culprit. An App called Applock Pro. I'm quite sure it came pre-installed. I think I only tapped on it to open and see what it is, and it started its dirty work. It's by "Go Dev Team". There are a bunch of apps doing this, and most seem to have the word GO in there somewhere. Any of you Verizon users here have that one on your phone?
    I had the same problem on my galaxy note 7 before installing anything, not sure if it was Verizon or Samsung but an update downloaded app lock pro and dg ignite and that's where the problem is coming from
    09-20-2016 03:43 PM
  2. French's Avatar
    OP: here is a thread that might help w the Miracast questions.
    I have ES File Explorer Pro and am not having these ad issues.
    09-20-2016 08:26 PM
27 12
  1. Malware help
    By miyanc in forum Android 6.0 Marshmallow
    Last Post: 09-03-2016, 06:57 PM
  2. Moto G - PC only recognises SD card and not internal storage... HELP!
    By charlenesbunnies in forum Ask a Question
    Last Post: 08-31-2016, 06:38 PM
  3. Voice control over bluetooth problem with Note 7
    By godspeed87 in forum Samsung Galaxy Note 7
    Last Post: 08-31-2016, 05:24 PM
  4. 450mAh charging on Tab S2 9.7 Help!!
    By Joshuang81 in forum Samsung Galaxy Tab S2
    Last Post: 08-28-2016, 01:33 PM
  5. Replies: 1
    Last Post: 08-28-2016, 10:59 AM
