10-09-2016 04:39 AM
43 12
tools
  1. Preach2k's Avatar
    08-28-2016 09:57 PM
  2. felloffthetruck's Avatar
    Glad I did not order any or these. I had a couple in my cart on Amazon.
    08-28-2016 10:12 PM
  3. stackberry369's Avatar
    Why are they unsafe?
    08-28-2016 10:18 PM
  4. Preach2k's Avatar
    I got the car charger. I will return it. I never used it yet.
    08-28-2016 10:18 PM
  5. Preach2k's Avatar
    May cause your battery to explode or do damage to your phone.
    08-28-2016 10:20 PM
  6. Strong_Genetics's Avatar
    If you plug it into a device that requires more power it will power that device... And if you then plug it into another device that requires less power it will deliver the same high power that the previous device needed and you will destroy the components in the device that doesn't require and cannot handle that power
    08-28-2016 10:22 PM
  7. traynor1987's Avatar
    You can only buy that specific model in America and Amazon stopped selling it already so I think you will be ok, just buy the usb a to use c one as that one is safe
    08-28-2016 10:31 PM
  8. Katrina White1's Avatar
    Hmmm...I bought a 2 pack of the adapters. I'll be on the lookout for posted issues. I thought Anker was reliable.
    08-28-2016 10:52 PM
  9. Jaycemiskel's Avatar
    I wish there weren't so many issues with USB C cables and adapters. They need to get this together.
    08-28-2016 11:25 PM
  10. Ry's Avatar
    08-28-2016 11:28 PM
  11. audri5's Avatar
    I have a USB c that I am using in my car. I don't intend to use it in any other way. It charges the phone while in the mount. Would it be safe since I don't intend to use it for anything else?
    08-29-2016 07:17 AM
  12. Jona005's Avatar
    I've learned with Samsung phones to pretty much use only Samsung cables/chargers.
    Serkle K likes this.
    08-29-2016 08:22 AM
  13. bertsirkin's Avatar
    I could be wrong (I'm no expert!), but in researching USB-C cables, I found that some contain a 56k ohm resistor in them, and, apparently, the purpose of this resistance is to prevent a power supply from supplying more power than the phone/computer is asking for.
    08-29-2016 09:15 AM
  14. NotAnAppleGuy's Avatar
    This doesn't affect the cables that came in the box right?
    08-29-2016 09:16 AM
  15. Preach2k's Avatar
    No. Nothing out of the Samsung Box is affected.
    08-29-2016 11:20 AM
  16. dpham00's Avatar
    They are pretty good. Not perfect but also... The only one that I know of to do a recall even though numerous other usb c cables have not met usb c spec.
    If you buy a third usb c cable, make sure it is Benny approved.
    08-29-2016 12:43 PM
  17. bertsirkin's Avatar
    Theoretically, Amazon isn't selling "bad" USB-C cables - Amazon will no longer sell USB cords that fry your laptop - Mar. 31, 2016
    08-29-2016 12:48 PM
  18. dpham00's Avatar
    But they don't check them out first... The customers would report it and then they would pull it with enough complaints
    08-29-2016 01:59 PM
  19. Kelly Kearns's Avatar
    That should be fine, but they we replace I'd you have one of the cables.
    The problem comes from using different devices with the cord.
    08-29-2016 02:01 PM
  20. Preach2k's Avatar
    I checked my car charger and it is an Aukey not Anker! So I am okay!
    msndrstood likes this.
    08-29-2016 04:16 PM
  21. felloffthetruck's Avatar
    I checked my car charger and it is an Aukey not Anker! So I am okay! https://uploads.tapatalk-cdn.com/2016...ac1724ace8.jpg
    I would still be nervous. I'm going to stick with only Samsung for the time being.
    Does Samsung even make a fast car charger with USB C ?
    08-29-2016 04:19 PM
  22. Preach2k's Avatar
    Verizon is selling a car charger. I do not know if it is an Fast Charger.
    08-29-2016 04:22 PM
  23. Kelly Kearns's Avatar
    Car chargers are fine and the only cable with an issue is the C to C cable and not the A to C cable.
    Preach2k likes this.
    08-29-2016 04:25 PM
  24. dsignori's Avatar
    So this was a single USB C to USB C cable right? I don't have any of that type anyway ..
    08-29-2016 04:33 PM
  25. Cotano's Avatar
    I almost brought a c to c. But I realized that would be stupid. The note wouldn't benefit from it. Nothing I owned would. All that would mean is I would have to replace all my fast chargers with type c types and gain no benefit for my cost.
    Even the one in the box was an a to c.
    I still wasted my money on c to a. Once i5 tried wireless I was hooked. I now own 3 samsung wireless chargers. 1 is an non fast normal charge mini pad. Only non samsung I'll have is the car wireless mount.
    My note may never be plugged in again.
    08-29-2016 05:00 PM
43 12
  1. Replies: 9
    Last Post: 10-06-2016, 05:12 PM
  2. General Hotspot and WiFi questions
    By ShaggyKids in forum Verizon
    Last Post: 09-08-2016, 08:02 AM
  3. unusual bluetooth issue, help please!
    Last Post: 08-28-2016, 09:48 PM
  4. Anti-Virus and Back Up/Restore?
    By Monique King-Viehland in forum Samsung Galaxy Note 7
    Last Post: 08-28-2016, 08:51 PM
  5. Replies: 0
    Last Post: 08-28-2016, 08:43 PM
