09-01-2016 03:03 PM
31 12
tools
  1. anon(9780053)'s Avatar
    Lost mobile data usage........6 hrs........apn settings seen right unless you can sgare yours,,,,,,,,,btw shows no wap setting..........before i have to can it or return for repairs
    08-28-2016 11:02 PM
  2. Almeuit's Avatar
    It shouldn't really need repairs. Have you tried a reboot and cache wipe from recovery to see if it helps it out of its funk?
    08-28-2016 11:28 PM
  3. anon(9780053)'s Avatar
    Lol
    worth a try;;;;;;;;;did 3 resets
    08-29-2016 12:27 AM
  4. Almeuit's Avatar
    Lol
    Hm.. Interesting. Try removing the SIM / replacing it back in and rebooting. See if that helps. If the APN settings are right it should work. The only thing I can think of causing the issue could be a local network issue with T-Mobile but usually that isn't the case.
    08-29-2016 12:54 AM
  5. anon(9780053)'s Avatar
    Popped in ole sim card and all gone; 4 g stayed on when turned off wifi' but new tnmobilr gave me 2 g 4 g and 3 g but none had data when i turned wifi off then mobile data icon dropped out; samsing said device fine sim not so nor data 1 day after sim inserted'
    08-29-2016 02:34 AM
  6. Tarah Sorber's Avatar
    My hubby had alot of issues when he took his LG G3 from Verizon to T mobile. nothing worked right and he could never receive system updates.
    08-29-2016 07:21 AM
  7. Almeuit's Avatar
    I'd go to T-Mobile and get a new SIM to see if that helps.
    08-29-2016 07:36 AM
  8. anon(9780053)'s Avatar
    they refused...............said will charge me 20///all bs
    08-29-2016 11:39 AM
  9. dpham00's Avatar
    Complain to John Legere on Twitter... He should be able to get you a replacement sim free since this is a service issue, not just buying a new sim
    08-29-2016 11:48 AM
  10. Almeuit's Avatar
    The data worked once you initially switched and just stopped recently -- correct?
    08-29-2016 12:04 PM
  11. anon(9780053)'s Avatar
    i like you moderators
    08-29-2016 12:29 PM
  12. Almeuit's Avatar
    Uh -- thanks? .
    08-29-2016 12:34 PM
  13. dpham00's Avatar
    Carriers also tend to be less helpful with connectivity problems if you don't have their phone... But hopefully it is just a bad sim which is an easy fix
    08-29-2016 12:56 PM
  14. anon(9780053)'s Avatar
    most times, when disable wifi 4g would jump ship. it would show 3 bars and no 3 g or 4glte. just ordered another sim.
    i feel its in vain. I HAVE UNLOCKED DEVICE, HOW ELSE WOULD I MAKE CALLS. for the most, data drops, wifi ok but when data dies no mms ability. yes you are and i are stumped. wont admit it but WAS or is vzw device, but tmobile sim service. say it. i can take it. it is unlocked period.
    08-31-2016 10:13 AM
  15. Almeuit's Avatar
    That just meant you had cell signal for calls but no data. I have to agree something wonky is going on since the VZW Note is capable of working on T-Mobile.
    Hopefully the new SIM will fix it for you.
    08-31-2016 10:17 AM
  16. TwitchyPuppy's Avatar
    Did you check your APN settings?
    08-31-2016 10:18 AM
  17. anon(9780053)'s Avatar
    apn set 22 times right
    08-31-2016 06:35 PM
  18. mfldmike's Avatar
    Because even though all Verizon phones are factory unlocked...the Verizon firmware locks the LTE bands for use on AT&T and T-Mobile.
    Just install the carrier firmware using Odin and you're good to go. Should be AP, CSC, .pit, and a couple more I'm missing. Don't have to mess with root or even APN settings once you install your carrier firmware. Then things like VVM work
    08-31-2016 06:58 PM
  19. Kelly Kearns's Avatar
    Aren't you still within the return time frame for Verizon? It might be best to return it to. Verizon, get your money back and buy the T-Mobile version.
    08-31-2016 07:39 PM
  20. Almeuit's Avatar
    It doesn't do this. It's unlocked and will work with any SIM. That's what it means by being unlocked. You're describing a locked phone.
    08-31-2016 07:58 PM
  21. mfldmike's Avatar
    No I'm not, please re-read my paragraph...Verizon disables bands 12 and 17 in their firmware. This is why you CAN pop any SIM in and still make/receive calls and text messages but data doesn't work. Just flash your carriers carrier firmware for it and it will allow ylu to use bands 12/17 AND data rather than displaying an "H" above your signal indicators without data.
    08-31-2016 08:11 PM
  22. Almeuit's Avatar
    Band 12 and 17 aren't the main bands so yes data will work. I am not sure where you think that's the only ones for data. It may be for Verizon but T-Mobile is mainly 2 and 4. 12 is used by T-Mobile but only in certain areas (a.k.a not their main band for LTE).
    08-31-2016 08:16 PM
  23. mfldmike's Avatar
    Instead of arguing with a person that's genuinely trying to help you dud you ever try to flash carrier firmware? Before I flashed AT&T firmware to the Verizon-branded Note 7 I have, I couldn't access data. Changing my SIM, APN Settings, restoring, etc...didnt help.
    08-31-2016 08:20 PM
  24. Almeuit's Avatar
    I'm not the one who made the post. I'm saying T-Mobile uses band 2 and 4 mainly with 12 in some areas. You just said that it won't work since 12 and 17 are apparently locked. That makes no sense.. Like at all. If the network doesn't use the bands what's it matter if those are supposedly locked?
    I guarantee I can grab a friend's Note 7 on VZW and he can use my T-Mobile SIM to get service.
    08-31-2016 08:25 PM
  25. mfldmike's Avatar
    And I can attest to the fact that I could get voice and text but no data UNTIL I flashed AT&T firmware...on a Verizon Note 7
    APN Settings didn't matter
    08-31-2016 08:27 PM
31 12
  1. Replies: 2
    Last Post: 10-15-2016, 05:04 PM
  2. Advanced Messaging on Note 7 Question
    By _Dark_fulgore_ in forum Samsung Galaxy Note 7
    Last Post: 08-30-2016, 12:16 PM
  3. Oneplus One to Note 7
    By 2Peks1Bird in forum Samsung Galaxy Note 7
    Last Post: 08-28-2016, 11:06 PM
  4. Deleting phone update file on samsung
    Last Post: 08-28-2016, 10:56 PM
  5. Replies: 0
    Last Post: 08-28-2016, 10:22 PM
