1. gboyegab's Avatar
    I have owned the note 4 and Note 5 I now own an S7 Edge would it make sense to get the Note 7 or wait for the Note 8
    08-29-2016 02:29 AM
  2. Hichem Pour Toujours's Avatar
    LoL, wait for Note 9
    08-29-2016 02:38 AM
  3. Torm558's Avatar
    Hard for anyone to answer but you since you know what you want to use the phone for. You've seen all the note 7 features by now. Any of them stand out above the s7 edge as a must have?
    08-29-2016 03:06 AM
  4. Snappy Phoenix's Avatar
    Wait for the Note 8. you already have a phone that's similar to the Note 7 minus the S pen and a slightly bigger battery. Same shape, same camera, you wouldn't feel a difference and are just wasting your money.
    recDNA likes this.
    08-29-2016 03:48 AM
  5. russel5150's Avatar
    I disagree. Ive had the note 2 3 4 5, and also have the s7 edge. The note 7 is not just and s7edge w a pen. In my opinion the note7 is better, i like the new grace ui, i like the edge screen is not as pronounced as the s7 edge.. and if you use the s pen than it is def worth it
    My opinion of course, others may vary, but the two are different enough that if you want a note back go w the 7, no need to wait for the 8.. tomorrow is not promised lol.
    08-29-2016 03:52 AM
  6. o4liberty's Avatar
    They are very similar with the note having a few extra features for an extra 100 dollars.
    08-29-2016 05:21 AM
  7. stevenjak's Avatar
    I personally went note 4, note 5, S7 edge, and am really happy to be back with the note 7. The pen, ui, screen curve, size, everything about it. So glad I changed.
    08-29-2016 08:13 AM
  8. Dukins's Avatar
    I loved the s7edge after I finally got it set up they way I needed without battery drain. Not in love with Note 7, I have had a few issues. I am going to stay with the Note 7 though, problems can be fixed. But not a very big difference.
    08-29-2016 08:18 AM
  9. chyeo1979's Avatar
    Note 7 is definitely a great phone, but it's simply too quick to upgrade your S7E unless you really want the s-pen (but then you ditched the Note 5 for S7E, hmm...).
    08-29-2016 08:23 AM
  10. jerrycau123's Avatar
    I have owned the note 4,5, and s7 edge and now the note 7.
    The note 7 is hands down the best phone I've ever owned!.
    The spen is an Amazing feature!.
    08-29-2016 09:54 AM
  11. ajb1965's Avatar
    I went from the S7 Edge to the Note 7 and have been very happy. I wanted the bigger screen and the pen. There are a few small differences in the software that I like, and the camera software changes are minor but handy.
    08-29-2016 10:51 AM
  12. Almeuit's Avatar
    I swapped but I use the S-Pen a lot so that is the benefit for me. If you won't use it that much it won't be worth it IMO.
    08-29-2016 10:55 AM
  13. Kelly Kearns's Avatar
    It isn't just a pen. The spen is an actual tool.
    Now if people don't use the spen for what it is, the Note isn't something they need, then go for the S7.
    Now for those of us that use the tool the spen, you can't do without one and no spen is out of the question.
    08-29-2016 10:56 AM
  14. jamesrick80's Avatar
    I would say s pen and secure folder....otherwise
    08-29-2016 11:11 AM
  1. Replies: 2
    Last Post: 10-15-2016, 05:04 PM
  2. Flashlight on the Note 7?
    By rhstrat77055 in forum Samsung Galaxy Note 7
    Last Post: 10-05-2016, 12:05 PM
  3. Where is the flashlight on the Note 7?
    Last Post: 10-03-2016, 11:36 PM
  4. Note 4 help needed, can't recover. Restart loop!
    Last Post: 08-30-2016, 08:28 PM
  5. Oneplus One to Note 7
    By 2Peks1Bird in forum Samsung Galaxy Note 7
    Last Post: 08-28-2016, 11:06 PM
