1. furby23's Avatar
    Okay so i have had iphones since the very first one.
    My new note 7 arrives tomorrow however i have no idea how to set it up with regards to optimizing it etc...
    I have done a bit of reading about the android subreddit and i understand i cant passively use this to its full potential as i do with iphones.. Im looking for the best guru on here to help me with a list of what to do for:
    • Best battery optimisation out of the box
    • How and when to disable imessages as ive heard it can stop you receiving text messages
    • The best email app that combines: gmail & outlook
    • is anti virus software needed?
    • How to get videos and games onto the VR, is there a specific app?
    • I have read that a factory reset has helped people get longer battery off the bat, is this needed?
    I will add more if I think.
    I just want to have it run best as possible and after dwelling in here for a while these are the main questions id be extremely grateful of the gurus to answer.
    Thanks for your time, i will be giving karma!
    08-29-2016 12:16 PM
  2. Carlo Villa's Avatar
    Congratulations, give your self time to play with this awesome little computer.
    Your biggest challenge will be Imessages, that's a pain in the butt because of Apple.
    furby23 likes this.
    08-29-2016 12:19 PM
  3. From A Buick 8's Avatar
    I signed out of iMessage the last week I was on my iPhone (on the actual iPhone first and the through the website just to make sure). The only issue I had was with one friend who had been sending to my email address instead of my cell number. Other than that no issues with getting text post iMessage
    furby23 likes this.
    08-29-2016 12:35 PM
  4. TwitchyPuppy's Avatar
    You clearly have no idea what you're talking about. It's super easy to do, because of Apple.
    Ludatyk likes this.
    08-29-2016 12:38 PM
  5. Carlo Villa's Avatar
    Oh yeah? Mister know it all? Instead of being an *****, why don't you tell the OP how to do it.
    furby23 likes this.
    08-29-2016 12:40 PM
  6. double923's Avatar
    Follow this instruction how to deregister iMessages:
    https://selfsolve.apple.com/deregister-imessage
    Note: in some case, people you had text to previously. They might have to delete the existing conversation and start a new one for you to receive the text on Note 7.
    furby23 likes this.
    08-29-2016 12:46 PM
  7. cwbcpa's Avatar
    Not sure if serious....lol.
    To the OP. It is much better than it used to be. I always just make sure I turn off imessage and FaceTime before I switch to an android phone. For the most part you should be ok. You will have issues with iPhone users that don't have "send as SMS" turned on and with group messages with iPhone users. Other than that it should be good. You can fix the group messages by starting a new group message from your Note 7. Good luck and enjoy!
    furby23 and Carlo Villa like this.
    08-29-2016 12:48 PM
  8. clg82's Avatar
    I am doing the exact same thing as well...I appreciate any input that the Android experts can help us with!
    furby23 likes this.
    08-29-2016 01:04 PM
  9. Monique King-Viehland's Avatar
    I also just switched from the iPhone 6s Plus to the Note 7. I turned off iMessages before I switched the phone number over on both my iPhone and iPad and I haven't had any issues.
    I thought Anti virus software was a good idea and I talked to a relative who works in IT and he suggested Bitdefender which is what I am using.
    So far, my battery life has been great - right out of the box, but I do not think a reset upfront could hurt.
    You may also want to transfer all of your contacts, photos, etc. over to Google Drive. That is what I did and it made the transition fairly smooth.
    Hope this helps.
    Monique
    furby23 likes this.
    08-29-2016 01:17 PM
  10. wookiee2cu's Avatar
    I believe he meant getting everything turned off prior to switching in order to not have issues with text messages from other iPhone users because he was using iMessage. I had issues with some text messages not coming thru for almost 2 weeks when I made the switch about 2 years ago and so did everyone else I knew because it turned out you had to request Apple to purge your phone number from their servers, this was before they built the website where you can now submit your info.
    furby23 likes this.
    08-29-2016 01:30 PM
  1. Scrolling in Youtube App Causes It to Crash
    By huntnyc in forum Samsung Galaxy Note 4
    Last Post: 08-30-2016, 02:53 PM
  2. is it just me or does the S7 edge outperform the Note 7?
    By Laserbutt in forum Samsung Galaxy Note 7
    Last Post: 08-30-2016, 09:46 AM
  3. Note 7 preorder from samsung.com
    By 1joeyisbest in forum Samsung Galaxy Note 7
    Last Post: 08-29-2016, 02:52 PM
  4. Does Samsung plan to release a new Galaxy Edge 2?
    Last Post: 08-29-2016, 11:31 AM
