1. jhimmel's Avatar
    I'm using the Samsung Browser "Internet". It's just fine, except I don't care for the fact that it loads the last viewed page whenever I open it. I see no way to change this. Am I missing something?
    08-29-2016 05:25 PM
  2. SpookDroid's Avatar
    Pretty much all mobile browsers work that way, I'm afraid. In order to avoid that, you need to specifically close the tab you're viewing before sending the browser to the background. Otherwise, whatever you were looking at before will open when you call the browser back to the foreground.
    08-29-2016 05:27 PM
  3. jlczl's Avatar
    Yes, there are settings for that. Tap the 3 dot menu on the upper right hand and click settings. Then click homepage. Then choose one of the options.
    08-29-2016 05:28 PM
  4. SpookDroid's Avatar
    That's different than loading the last viewed page.
    08-29-2016 05:30 PM
  5. jlczl's Avatar
    Thanks. I see what he's asking now.
    No, for that you can't do it on the Samsung browser but there is some browsers that will truly exit and close the app when you exit it. One of those is ghostery browser which is actually a pretty neat little browser that is fairly light and fast.
    08-29-2016 05:40 PM
  6. msm0511's Avatar
    I thought they did, but couldn't remember.
    One option is before closing the browser open a new tab so it opens on whatever he has set as homepage. I used to do that a lot on my iPhone so I could save articles that weren't worth bookmarking, but that I wanted to read.
    08-29-2016 06:21 PM
  7. jhimmel's Avatar
    I see. Thank you all.
    08-29-2016 07:05 PM
  8. double923's Avatar
    I start using Samsung stock internet browser ever since Note 5 got update to 6.0. With the Note 7, I like it even more. It supports extension which you can get the Ads block for and it works very well. I blocked ads from my entire home network and now I can block the ads while on LTE just like iOS Safari which is really nice.
    08-29-2016 08:26 PM
  1. SD card reader for Note 7
    By Gophers06 in forum Samsung Galaxy Note 7
    Last Post: 10-04-2016, 04:36 PM
  2. This doesn't bode well for the radios in the new Pixel phones Or does it?
    By quelquehomme in forum Google Pixel & Pixel XL
    Last Post: 09-05-2016, 04:53 PM
  3. samsung Sview and Verizon tempered glass protrctor
    By Jude526 in forum Samsung Galaxy Note 7
    Last Post: 08-29-2016, 06:36 PM
  4. Replies: 0
    Last Post: 08-29-2016, 04:18 PM
  5. How long does Samsung manufacture carrier exclusives?
    By Law2138 in forum Ask a Question
    Last Post: 08-29-2016, 04:15 PM
