1. bigmo555's Avatar
    Anyone know why this popped up? Seems silly, especially when I setup finger and iris.....
    08-30-2016 11:38 PM
  2. Jewels81's Avatar
    Anyone know why this popped up? Seems silly, especially when I setup finger and iris.....https://uploads.tapatalk-cdn.com/2016...52d2429413.jpg
    Maybe it didn't recognize your fingerprint. Did you try it again? I know on my note 5 if i didn't do the fingerprint just right it would make me do pin. I haven't played with the fingerprints on note 7 except to set it up lol. I use iris scanner mostly.
    08-30-2016 11:42 PM
  3. msm0511's Avatar
    When did it happen? If you reboot your phone for example you have to use the pin before you can use fingerprint again.
    08-30-2016 11:42 PM
  4. bigmo555's Avatar
    Don't remember when exactly it started. Sometimes if I lock the screen while in an app it won't happen, maybe 33% of the tume it'll accept my fp.
    08-30-2016 11:58 PM
  5. PRGDR's Avatar
    From what you say here, I believe the reason is what it was Jewels81 explained, it shows up as the failsafe security mechanism because it does not accept the fp. There's not much to do about it, I think.
    Jewels81 likes this.
    08-31-2016 06:22 AM
  6. bigmo555's Avatar
    Ok, tried removing irises and fingerprints. Then re-added irises.
    08-31-2016 06:28 AM
  7. PRGDR's Avatar
    Now, this ......
    True, it sounds like too much of a coincidence that it has troubles recognizing finger prints and iris. It is probably worth it talking to Samsung about it, if it is a faulty unit, you should get it fixed (or a new phone), otherwise you will have reported a bug...
    bigmo555 likes this.
    09-01-2016 06:38 AM
  8. bigmo555's Avatar
    I believe that I discovered the culprit.
    My Power toggles app. With this widget, if I lock the screen I cannot unlock it with iris or fingerprint. If I lock normally, I can.
    09-01-2016 06:25 PM
  9. PRGDR's Avatar
    Great! Glad you could fix it. Thanks for letting us know.
    09-02-2016 06:13 AM
  10. 0355's Avatar
    That's perfectly normal. Android security policy prevents an app to lock the screen and then spoof the fp.
    If the system finds out an app or an overlay locked the screen then asks for back up pin instead of the fingerprint.
    There's no way to use fingerprint or iris to unlock the phone with an app that locks the screen via software.
    Oh well there is actually a way. There should be an app which doesn't lock the screen but dims it while setting timeout to a minimum. This way the screen would lock "naturally" and the security policy measures wouldn't apply.
    09-02-2016 06:52 AM
  11. bigmo555's Avatar
    That's logical. I'm just glad that it's resolved.
    09-02-2016 02:30 PM
  1. Note 5 drops all signal, requires restart
    By jmj227 in forum Samsung Galaxy Note 5
    Last Post: 09-03-2016, 11:36 AM
  2. Package require signature?
    By clg82 in forum Samsung Galaxy Note 7
    Last Post: 08-30-2016, 11:46 PM
  3. How to open iphone pins
    Last Post: 08-30-2016, 06:54 PM
  4. Replies: 0
    Last Post: 08-30-2016, 06:43 PM
  5. Replies: 1
    Last Post: 08-30-2016, 04:45 AM
