1. Halloweenoreo's Avatar
    Has anyone bought any of the type c chargers from Amazon?
    If so
    Any issues with the cheaper ones?
    Or should I spend the few extra bucks and get one from best buy or Verizon?
    08-31-2016 05:39 PM
  2. Almeuit's Avatar
    I wouldn't buy cheap USB-C cables as this can be an issue.
    Are you looking for a C to C cable or A to C?
    Kelly Kearns likes this.
    08-31-2016 05:41 PM
  3. Delirious D's Avatar
    I bought a 6ft micro usb and just put the adapter that came with the phone it. Havent had an issue paid $5 for the cable. At one of my favorite novelty stores called 5 below. Didnt feel right spending $17 on a usb c. Which seem hard to find at local stores.
    still using the fast charging block that came with the phone.
    The cord that came with the note 7 is just toooooo darn short. Using it in my car.
    rebma85 likes this.
    08-31-2016 05:47 PM
  4. fgcchevy's Avatar
    I got a pair of cheap cables from Amazon for $8, I think I'll spend the extra money next time as they are really low quality, imo.
    08-31-2016 05:50 PM
  5. Halloweenoreo's Avatar
    Looking for a to c.. I came from the note 3 so that charger doesn't work an need one more extra cable. Have a Wireless for the house but need a travel one
    08-31-2016 05:51 PM
  6. Amb312's Avatar
    I bought a 6ft one on amazon. So far, so good
    08-31-2016 06:14 PM
  7. Jona005's Avatar
    I found an oem wall charger for the Note 7 on Amazon for $20.00. It's hit or miss whether it's a legit item, but I got lucky I guess.
    08-31-2016 06:14 PM
  8. SteelGator's Avatar
    I bought these from Amazon. They have worked well, and are the most premium feeling cords I have ever owned. They were also tested and reviewed by Benson Leung from Google. I recommend them based on my experience to date.
    If you search his name in the forums you will see the contribution he has made.
    msndrstood likes this.
    08-31-2016 06:41 PM
  9. sheba510's Avatar
    I bought the USB-A to USB-C cables made by Cable Matters. They are only USB 2.0 cables but I bought these for charging, not data.
    https://www.amazon.com/gp/product/B0161GVULY/ref=oh_aui_detailpage_o00_s00?ie=UTF8&psc=1
    08-31-2016 06:59 PM
  10. Kelly Kearns's Avatar
    I would not buy a cheap cable for this phone. That doesn't mean you have to pay and arm and a leg.
    Anker and Aukey on Amazon have good prices and those should be good. Anker did have a C cable that was a problem and they have recalled it.
    bigmo555 likes this.
    08-31-2016 07:32 PM
  11. Almeuit's Avatar
    Ensure to look for a review by Benson for A to C cables. If he approved them then it is safe to buy. Example below of an Anker A to C cable where he gave it a 5.
    08-31-2016 07:50 PM
  12. mmsean's Avatar
    I bought a cable matters one
    08-31-2016 08:07 PM
  13. cynth.hgn's Avatar
    I just bought the adapter so I can use all the Samsung cables I have collected over the years ๐Ÿ˜Š
    08-31-2016 08:49 PM
  14. Kelly Kearns's Avatar
    Some people have reported not being able to transfer data using some adapters.
    08-31-2016 08:50 PM
  15. cynth.hgn's Avatar
    Oh, I haven't tried to transfer data with the adapters yet. Good to know though. When I need to, I'll just use the usb-c it came with I guess.
    08-31-2016 08:52 PM
  16. vientiane's Avatar
    I got choetech, bought from amazon. however data transfer didn't work, only charging is ok.
    08-31-2016 09:05 PM
  17. mcgeorge36's Avatar
    I bought some A to C ones from Best Buy the day I got the phone. One was a Belkin(6 ft.), the other two were the Best Buy brand (10 ft.). Yeah, probably a little more expensive, but no issues. I didn't feel like trying not to lose the adapter or buying multiple adapters. I'm not doing any data transfer at all & I'm not using anything other than Samsung plugs (except for in the car, it's the Best Buy brand quick charge one). So far, so good....
    08-31-2016 09:23 PM
  18. Hurleygm's Avatar
    I bought the same one. I haven't tried data transfer though.
    08-31-2016 11:11 PM
  1. Note 7 Edge Panels disappear after power cycle or reset
    By Arthur Viola in forum Samsung Galaxy Note 7
    Last Post: 09-01-2016, 09:10 AM
  2. Hotspot on my Note 4 won't connect to a device.
    Last Post: 09-01-2016, 12:29 AM
  3. Galaxy note 7 clipboard settings
    By Patsredsox72 in forum Samsung Galaxy Note 7
    Last Post: 08-31-2016, 08:01 PM
  4. Galaxy note 7 internet history
    Last Post: 08-31-2016, 07:27 PM
  5. Google's ADT-1 Power/Dev cable
    By sandog78 in forum Ask a Question
    Last Post: 08-31-2016, 05:34 PM
