1. brian447's Avatar
    Using the stock Samsung calendar app I am not getting all the notifications.
    For example: If I set a calendar appointment for 3:00 PM for an important meeting I will usually set several reminders...one reminder a day before, a second reminder an hour or two before and a third reminder for 10 minutes before the appointment. This has always worked well before and I have always received all the set notifications (with my S3 and S5).
    Now, with my new Note 7 I will get the first reminder notification but none of the rest, despite them still showing in the calendar.
    I have run a few tests and each time I will get the first reminder but none of the other set reminders will alert me in any way.
    Any ideas?
    08-31-2016 08:01 PM
  2. Justin Paradis's Avatar
    I would like to know the answer to this since also have a similar problem.
    08-31-2016 09:43 PM
  3. ajb1965's Avatar
    Are you using the Samsung account, or another account like Google in your calendar? I have my Google calendar synced and I haven't noticed this issue.
    08-31-2016 10:45 PM
  4. left4dead's Avatar
    I believe I read somewhere that your Samsung calendar (under Samsung Account) has to be enabled to syncing for your Google Calendar notifications to show up and work properly. Give that a go and see if it works.
    09-01-2016 12:18 AM
  5. brian447's Avatar
    Ran several tests today and made sure this option was checked. Still having the same problem.
    I am using the native Samsung calendar app that is synced with my google calendar.
    I am wondering if its a bug in the app because I have used the default/native Samsung calendar app the same way for over 6 years with no problems until I switched to the Note 7.
    Any other ideas?
    09-01-2016 06:50 PM
  6. Gellerama's Avatar
    I have the same issue on my stock calendar app on my galaxy s7. Calendar notifications randomly fire, don't fire or fire Kate. I have tried multiple things, including wiping my phone. The random nature of this issue is Maddening. Any thoughts?
    10-21-2016 05:37 AM
  1. Samsung Galaxy S7 Edge (G935F) root problem
    Last Post: 03-03-2017, 02:19 AM
  2. Replies: 2
    Last Post: 08-31-2016, 11:38 PM
  3. Problem in messenger
    Last Post: 08-31-2016, 08:14 PM
  4. Im having problems with sync in my ford mustang
    Last Post: 08-31-2016, 07:48 PM
  5. Why is my note 3 led notification light not working
    Last Post: 08-31-2016, 07:12 PM
