Best VR options other than OEM?
RobSteal
77
Has anybody had any luck with any VR devices other than the OEM unit? There's so many on Amazon and was wondering if anybody had one that worked to their liking and also worked with Type C.
maf113
700
The others support Google cardboard to some extent. Some better than others. Samsung gear VR is by far the best option for the Galaxy line. IMHO. It has additional sensors to detect your head movement better as well as better optics.
Before buying one of the others on Amazon get a cheap Cardboard kit and try it out. Then go to best buy and try the gear VR. See the difference.
Chelrie
