09-02-2016 04:49 PM
58 123
tools
  1. TylerLV76's Avatar
    anybody know where to get a list of what banks Samsung pay accepts?
    Which banks and credit cards are compatible with Samsung Pay?
    09-01-2016 02:53 PM
  2. erasat's Avatar
    Google search, Samsung Pay - Safe and Simple Mobile Payments
    09-01-2016 02:56 PM
  3. Highrisedrifter's Avatar
    See the top of my post, two up from yours.
    09-01-2016 02:57 PM
  4. pinkvikchick's Avatar
    They don't? I have my Wells Fargo HSA debit card in Samsung Pay. Have you checked recently?
    Very weird, yes, I checked when I got the phone and when I tried to put my card in, it said Samsung Pay doesn't support my card.
    09-01-2016 02:58 PM
  5. toenail_flicker's Avatar
    If you got your phone by the 28th of August Sammy will send you $20 to your phone if you setup and use Sammy Pay. That was motivation enough for me.
    09-01-2016 03:01 PM
  6. pinkvikchick's Avatar
    I did some digging and these WF cards are accepted in the USA according to Which banks and credit cards are compatible with Samsung Pay?
    I just checked again, and viola, it works. :-) Sometimes I'm ok with being wrong
    toenail_flicker likes this.
    09-01-2016 03:01 PM
  7. toenail_flicker's Avatar
    That sucks.
    09-01-2016 03:01 PM
  8. TheLegoJoker's Avatar
    As others have said, if your bank supports Samsung Pay I see no reason to use anything else. I've had one hiccup in several efforts. I am extremely pleased with it.
    09-01-2016 03:02 PM
  9. 1213 1213's Avatar
    If your bank supports Samsung Pay, then you should go with that. Apple Pay and Android Pay use NFC, but Samsung Pay uses MST as well as NFC, so you can basically use it anywhere you can use your card. Which is basically the point of the service, to substitute your card.
    09-01-2016 03:03 PM
  10. Almeuit's Avatar
    Check here -- Which banks and credit cards are compatible with Samsung Pay? .
    clg82 likes this.
    09-01-2016 03:14 PM
  11. pinkvikchick's Avatar
    That sucks.
    It does support it, it does!! I tried JUST NOW and went through. I am so happy!
    09-01-2016 03:37 PM
  12. toenail_flicker's Avatar
    Web of trust doesn't like that link - says it has a poor rep.
    Here's the Samsung link.
    09-01-2016 03:48 PM
  13. toenail_flicker's Avatar
    WooHoo!
    pinkvikchick likes this.
    09-01-2016 03:48 PM
  14. TylerLV76's Avatar
    Huh? It is the Samsung link.Exact same as yours lol.
    09-01-2016 03:50 PM
  15. whtchdr's Avatar
    Android, only because Samsung doesn't support Wells Fargo yet....
    Actually they do. That is the bank I use with Samsung Pay.
    09-01-2016 04:32 PM
  16. pinkvikchick's Avatar
    I posted earlier that I got it to work...
    09-01-2016 04:36 PM
  17. toenail_flicker's Avatar
    Weird. When I see your link and use it there is an odd link and name that has nothing to do with Samsung. Did you use a link shortener or something? I'll see if I can replicate it. I tried twice with the same results.
    09-01-2016 05:29 PM
  18. TylerLV76's Avatar
    Nope just copied the link from the chrome address bar and pasted it
    09-01-2016 05:34 PM
  19. toenail_flicker's Avatar
    So there are two links here that give me the same info and block. Here's what I see for the the link and info on both. Take a look at the url and the icon for WOT.
    09-01-2016 05:36 PM
  20. toenail_flicker's Avatar
    Look at the sc I just posted and look at the beginning of the url. It's kq...something... and Samsung is at the very end. Mine is obviously from FF.
    09-01-2016 05:37 PM
  21. TylerLV76's Avatar
    Umm lol. Not really sure what thats all about.
    09-01-2016 05:39 PM
  22. clg82's Avatar
    Samsung pay only uses Wells Fargo?
    09-01-2016 05:53 PM
  23. SpookDroid's Avatar
    Nope, they have a bunch of banks on board.
    09-01-2016 05:54 PM
  24. toenail_flicker's Avatar
    Yeah. Was yours from Chrome desktop, or N7 or???
    09-01-2016 05:59 PM
  25. TylerLV76's Avatar
    N7 I believe and when I open the link on my desktop its still the samsung site. Ill try it at home in a bit and see.
    09-01-2016 06:02 PM
58 123
  1. Help transferring files from phone to laptop
    Last Post: 09-03-2016, 05:25 AM
  2. How do I get my Samsung Note 4 to update more often
    Last Post: 09-01-2016, 11:09 AM
  3. samsung galaxy note 5 first time charging
    Last Post: 09-01-2016, 10:47 AM
  4. Replies: 0
    Last Post: 09-01-2016, 10:21 AM
  5. My 4th Samsung s4 screen turns green again !!!!!!!!!!
    Last Post: 09-01-2016, 10:10 AM
