09-05-2016 06:32 PM
34 12
tools
  1. toenail_flicker's Avatar
    Neither work for me. Trying a 30-sec shutdown and reboot, but doubt that will help.
    Still spinning, but letting it ride for right now. May need to go outside too. I did the compass calibration, at least I think I did.
    09-03-2016 09:13 PM
  2. MikeS1971's Avatar
    Probably a dumb question, but where is smart lock in the settings menu? I was able to find it be doing a search while in the settings menu, just curious how to go directly to it.
    Edit. Nevermind. Found it.
    toenail_flicker likes this.
    09-04-2016 01:03 PM
  3. Ca_lvn's Avatar
    Thanks to this post im now using this feature.
    However the map had me off by 2 short blocks had to respotion the gps map dot to the correct address.
    Gps has always Ben accurate on the phone
    09-05-2016 04:05 PM
  4. toenail_flicker's Avatar
    Even after the Sprint update (I was hopeful) it still just spins and locks me all the time. Maybe on the recall replacement.
    09-05-2016 04:12 PM
  5. Ca_lvn's Avatar
    Do you have lacation survices turned on ,you know the one that gives google more access then they should have.
    Don't remember were in settings but you might try that.
    09-05-2016 05:07 PM
  6. juergen99's Avatar
    This may not be the perfect solution but..... Do you have a bluetooth device that's always at home? You could use it as a trusted device. I have a moto360 watch. Even when I am not wearing it, it is in its charger and my phone connects. Unfortunately the range is not good enough to cover all areas of my house.
    09-05-2016 05:20 PM
  7. toenail_flicker's Avatar
    Yeah. I've checked everything 3 or 4 times.
    09-05-2016 05:26 PM
  8. toenail_flicker's Avatar
    Interesting idea. Thanks! I didn't think of doing that.
    ETA - that will help in the yard and that's a big help. But it locks itself when I'm two ft away. I've quit worrying about it. N7's going back anyway.
    09-05-2016 05:27 PM
  9. MikeS1971's Avatar
    I've been trying to use this feature with it detecting my FitBit. Even though the phone is with me and the FitBit on my wrist all day, I have to reconfigure the phone to detect my FitBit several times a day. It's like it completely forgets it. Same goes if I have set to remember my location.
    09-05-2016 06:32 PM
34 12
  1. Are there no unlocked versions of the Moto Z for a Verizon customer?
    By XDCX in forum Moto Z Play & Z Play Droid Edition
    Last Post: 09-06-2016, 05:19 PM
  2. I accidentally erased my ringtones on my phone
    Last Post: 09-01-2016, 10:55 PM
  3. What is happening with the apps on my phone?
    Last Post: 09-01-2016, 09:20 PM
  4. I have my AOD on the Edge/Side of my phone how do I remove this
    By Gh057iN7he6 in forum Samsung Galaxy Note 7
    Last Post: 09-01-2016, 09:14 PM
  5. Forgot backup password is there anyway to get into phone
    Last Post: 09-01-2016, 09:10 PM
