What is your battery temperature while charging?
Carlo Villa
655
Here's mine....lol will explode ???
toenail_flicker
4,677
Like what???
1. Stay calm, I could be wrong. I have no real idea what the safe temps are. Just sounds hot to me.
2. Try turning off fast charging IF it is enabled.
3. Make sure you are using "good" chargers. Right now the best to use would be the one that came with your phone or a wirless that is known to be good and safe, i.e. you used it before without heat issues with other phones.
4. Make sure to set things up in Cooler Master so that you get notifications, its abilities to cool are authorized, etc.
dpham00
Moderator Team VP
Moderator
Apr 23, 2011
30,108
200
63
I prefer battery monitor widget pro. It tells you temp, charging rate, screen on/off.. Lots of good stuff and logs data
phillipeino
7
My Note 7 stays around 80-90 degrees Fahrenheit. It feels abnormally warm once it gets past 85 degrees. This phone is constantly running warm, from light use and even when it's just sitting in my pocket.
FarajWala800
