1. badkitties's Avatar
    Samsung reversed course and brought the MicroSD card slot back on the Note 7.
    If they did the same with the removable battery, there is no need to issue a worldwide
    recall on the Note 7, right? All they need to do is to ship out free new batteries to
    every registered Note 7 owner. (which probably saves them hundred of millions of
    dollars.. or trillions or Korean Won? )
    Or am I wrong? Is the exploding battery cause by more than just the battery itself?
    09-03-2016 02:56 PM
  2. felloffthetruck's Avatar
    Problem is that the Note 7's battery is not removable.
    09-03-2016 03:00 PM
  3. Jerry Hildenbrand's Avatar
    The issue could be caused by a bad battery, bad logic in the power management circuitry, bad components in the PM circuit, a bug in the software or a manufacturing flaw.
    We have no idea which may be an issue.
    09-03-2016 03:01 PM
  4. Viscomi4444's Avatar
    Here we go with the removable battery. It's never going to come back. A non removable battery is better because you know you arent getting any plastic cheap phone.
    09-03-2016 03:21 PM
  5. Rukbat's Avatar
    If Samsung had only opened their ears for a few seconds, they would have heard that the only thing keeping people from ordering the 7 without even knowing the price was the lack of a removable battery.
    They fixed the lack of an SD card - maybe the 8 (9? 10?) will have both the card and a removable battery. Changing the battery is trivial - but opening the phone voids all warranties.
    And, as Jerry said, the problem might not be with the battery. (You can get nice fireworks from a perfectly good lithium battery. Which airline blew up the everglades [a big chunk, anyway] because of an inherent problem with lithiums?) I think Jerry left out the charger too. There have to be some problems you can cause in the charger that will overheat the battery.
    09-03-2016 04:54 PM
  6. njshoremom4gurlz's Avatar
    This sucks
    Sorry but it does
    Life goes on but I never ordered wanted to wait it out and now I'm like ugh
    09-03-2016 04:58 PM
  7. Rukbat's Avatar
    It's "pick a phone that's almost the one you wanted, but leaves a large hole, or choose a phone you never wanted. I'd order the 7 now if the battery were removable (and the problem were in the battery or something else I could replace easily). But hot pants? I'll wait a while.
    09-03-2016 05:36 PM
  8. Kelly Kearns's Avatar
    Yes they would, it would be a recall on all batteries everywhere, complete with a battery shortage.
    09-03-2016 05:54 PM
  9. Mike Dee's Avatar
    The type of battery does not dictate plastic or metal phone or how cheap it is.
    09-03-2016 05:59 PM
  10. Ev C's Avatar
    Give it a rest with the removable battery already.
    09-03-2016 06:16 PM
  11. bembol's Avatar
    Question. How was sales between the Note 4 & 5. Did it increased because of the Premium build?
    As the old argument goes, what's the difference if one is just going to Case it up.
    As long as it's Waterproof, has microSD and Wireless Charging I don't really care anymore.
    09-03-2016 06:41 PM
  1. The More I Use It...
    By toenail_flicker in forum Samsung Galaxy Note 7
    Last Post: 09-03-2016, 10:22 PM
  2. Replies: 1
    Last Post: 09-03-2016, 07:34 PM
  3. Is it possible to change camera flash intensiry?
    Last Post: 09-03-2016, 07:08 PM
  4. Replies: 0
    Last Post: 09-03-2016, 07:07 PM
