re: Another (possible) Note 7 burnt up in Massachusetts
These phones are all ticking time bombs. They all have a design fault that goes beyond the battery. They are missing voltage protection that wouldn't allow a faulty battery to overheat and catch fire. Every day more reports will surface as long as these phones are allowed to to be used. Samsung wouldn't be recalling them all for a few bad batteries.
The problem "may" be voltage regulation in the phone and/or battery, but it's probably more complicated than that.
The USB-C specification allows for higher charging current, and, from what I understand, it's up to the cable to control the charging current (and maybe voltage as well). Bad cables have been responsible for frying devices using USB-C. Unfortunately, USB-C is fairly new, and it appears that everything hasn't been worked out yet. (see
USB Type C and 3.1: clearing up the confusion)
See this article on USB-C cables:
How to Buy USB Type-C Cables That Won’t Fry Your Gadgets - a quote from there is:
"...a standards-compliant cable will make sure
that the client tries to draw only as much
electricity as the host can provide."
I suspect that batteries and/or charging circuits in USB-C devices will have to be designed to double-check what the cables are providing, to account for inadequate cables.
This is new and evolving technology - I'm guessing that Apple is doing a lot of reviewing of their new phone before they release it!
