1. NotAnAppleGuy's Avatar
    Considering that the recent issues with the batteries requires an entire phone swap, do you think that Sammy is now more inclined to go back to swappable batteries? Seems less expensive to me.
    09-04-2016 11:51 AM
  2. Carlo Villa's Avatar
    No, just a bump on the road.
    09-04-2016 11:52 AM
  3. dlcpa's Avatar
    Nope, I had the insides of my Note 2 replaced because of a bad server address for MS Exchange acts, provided by Samsung, and one of the batteries bellied and swelled and if permanently in a phone would have exploded. The was hot, fried the battery and the memory.
    Now the Note 2 can't find satellites and looks for them all day long. The phone gets hot, battery life is terrible and the battery swells like a pregnant woman. If it was a permanent battery, without location services turned off, it would have exploded. Samsung, WTF is wrong with you. Permanent batteries are dangerous. Exchangeable batteries have the safety valve of not fitting if something in the caused them to expand. It also is cautionary to protect the rest of the phone like memory. For this information that your executives can't figure out, you can send me the next Note with exchangeable batteries. I just bought a lightly used Note 4. And I am sending you back my Note 2 so you can fix it or replace it, as the GPS antenna is obviously no good.
    Better get your act together before LG beats your butt by putting replaceable batteries in the v20.
    dlcpa@live.com
    Attached Thumbnails Is It More Cost Efficient To Go Swappable Battery?-20160904_123621.jpg
    09-04-2016 12:00 PM
  4. TwitchyPuppy's Avatar
    Nope. Bult-in batteries are way to trendy..
    09-04-2016 12:00 PM
  5. NotAnAppleGuy's Avatar
    Really Carlo? So replacing and trashing the entire phone is cheaper than a design with a removable battery? Guess the recalled phones will become the next "refurbished" ones?
    09-04-2016 12:22 PM
  6. Almeuit's Avatar
    I don't think so. I doubt they change their whole design when this was an unintended defect that I'm more than sure they'll double check to not repeat with the next phone.
    Carlo Villa and Kelly Kearns like this.
    09-04-2016 12:28 PM
  7. Kelly Kearns's Avatar
    No I don't think so. First replacing and trashing the phone is not required if you have a battery problem.
    One thing, if your phone is stolen and the battery removed, you aren't going to trace it.
    Less parts to break, less gaps on the phone for dust and dirt, slimmer phones.
    Sealing the battery means less likely to damage a battery. Also sealing the phone means everything inside is covered and protected.
    09-04-2016 12:30 PM
  8. Carlo Villa's Avatar
    IPhone has been extremely successful with this design. The Note4 with removable battery was ok but I didn't care for the squeaky sound on phone if pressed too hard because of its Plastic back.
    09-04-2016 12:41 PM
  1. Copperhead is APN issues on nexus 6p
    By Turner Atteberry in forum Nexus 6P
    Last Post: 09-06-2016, 12:05 PM
  2. Wondering if the free 256gb will still be shipped out to me
    By juliobx2012 in forum Samsung Galaxy Note 7
    Last Post: 09-04-2016, 09:28 PM
  3. Unrooted Nexus 5x is stuck in boot loop
    Last Post: 09-04-2016, 12:23 PM
  4. Why my m7 newly bought phone battery running fast
    Last Post: 09-04-2016, 12:05 PM
  5. I am trying to connect my tablet to my tv
    Last Post: 09-04-2016, 11:13 AM
