Not sure why but when I go to Settings/Advanced Calling/When Roaming there are no labels on the selection items.
Anyone else have this problem?
//uploads.tapatalk-cdn.com/20160906/186aad2a50df64013acca069b9dce499.jpg
//uploads.tapatalk-cdn.com/20160906/e14c66a092dd4e4ed133e03afb6efd0f.jpg
Thanx. That was it. I should have thought of that.Are you using a theme? I've seen some odd menu behavior (including in the Android Central app) where menu selections are basically invisible. Try going back to the stock theme and check that menu to see.
