1. lanenubia's Avatar
    Not sure why but when I go to Settings/Advanced Calling/When Roaming there are no labels on the selection items.
    Anyone else have this problem?
    09-06-2016 08:30 AM
  2. vmmatty's Avatar
    https://uploads.tapatalk-cdn.com/2016...69b9dce499.jpg
    https://uploads.tapatalk-cdn.com/2016...3afb6efd0f.jpg
    Are you using a theme? I've seen some odd menu behavior (including in the Android Central app) where menu selections are basically invisible. Try going back to the stock theme and check that menu to see.
    09-06-2016 08:52 AM
  3. lanenubia's Avatar
    Thanx. That was it. I should have thought of that.
    09-06-2016 12:04 PM
  1. Note 5 power button Fried. Need a way to turn on
    By mrsmobbins101 in forum Samsung Galaxy Note 5
    Last Post: 09-21-2016, 09:53 PM
  2. How do I track my monthly usage on my Huawei P8lite
    Last Post: 09-09-2016, 09:08 PM
  3. What is this symbol i have on my htc m8?
    Last Post: 09-06-2016, 08:18 AM
  4. How do you put a signiture on text messages with s7e.
    By Mrluky in forum Samsung Galaxy S7 edge
    Last Post: 09-06-2016, 08:12 AM
  5. Cannot make or receive calls on Moto g4
    Last Post: 09-06-2016, 07:16 AM
