1. cableghost's Avatar
    Is it possible to add a Secure Folder Shortcut to the Edge Panel?
    09-08-2016 12:34 PM
  2. NCTRNL2's Avatar
    Yep you can add it to the Apps panel on the Edge.
    09-08-2016 12:48 PM
  3. cableghost's Avatar
    Really, how? They don't show in the list of apps to select from.
    09-08-2016 12:57 PM
  4. Strong_Genetics's Avatar
    Do you have your secure folder visible or do you have the option selected to hide it? If its not hidden then it should be able to select......I keep my secure folder in my apps panel aswell..
    09-08-2016 01:06 PM
  5. cableghost's Avatar
    I may have misspoke... What I really want is a shortcut from one of the apps in the secure folder to show in the edge panel.
    09-08-2016 01:17 PM
  6. Strong_Genetics's Avatar
    I believe you can only link a task that leads you into a app in the secure folder.(Tasks Edge)..You cannot not do it in the apps edge cause the apps in the secure folder is segregated and wont show up in the normal UI
    09-08-2016 01:20 PM
  7. keepnitreel's Avatar
    That's not gonna happen...
    Edit: My bad, i just did it with fb... it's possible
    2nd edit: oops, sorry wrong fb attached... the secure fb wouldn't show as an app option.. So back to my original statement...
    09-08-2016 01:21 PM
  8. cableghost's Avatar
    Bummer. Thanks for the input.
    09-08-2016 01:24 PM
  9. smooth4lyfe's Avatar
    Then it wouldn't really be secure now would it lol since anyone can access the edge panel
    09-08-2016 01:57 PM
  10. cableghost's Avatar
    Well, that depends. It could have still required you to provide SF security credentials to open it. Moot point now though.
    09-08-2016 02:18 PM
  1. Cant get my phone to factory reset
    By Blues Fan in forum Samsung Galaxy Note 7
    Last Post: 09-24-2016, 06:37 AM
  2. Replies: 0
    Last Post: 09-08-2016, 12:20 PM
  3. Replies: 1
    Last Post: 09-08-2016, 12:13 PM
  4. Replies: 1
    Last Post: 09-08-2016, 11:55 AM
  5. S7 Edge Screen Protector Help
    By EdwardGabriel in forum Samsung Galaxy S7 edge
    Last Post: 09-08-2016, 11:41 AM
