anon(5719825)
Retired Moderator
Well the headset jack is gone but now instead of the headset jack, you plug headphones into the charging port or lightning port as it's called. It does come with an adapter so you can use other headsets too.I think removing the headset jack was a mistake. That's one thing that would keep me from buying it, along with no SD card.
Anyways, best of luck to everyone with their Note 7s. I know all of this has to be a major headache.
