09-17-2016 04:55 PM
85 ... 234
tools
  1. Morty2264's Avatar
    Called the exchange phone number, and they told me to call Samsung for arrangements for the drop off.....
    I think it's gonna be a rough day...
    Please keep us updated!
    Also, side point: You live in the Québec area?! I was born there! Love that city!
    09-16-2016 09:30 AM
  2. felloffthetruck's Avatar
    I just insered my bell sim card, and phone did a recovery boot, bluescreen and deleted something, and then did a reboot, does someone had that ?
    So, do you think the back was removed and the battery replaced on your replacement Note 7?
    Can you see any signs under the back glass or on the edges on the back that maybe it was opened?
    09-16-2016 09:34 AM
  3. chriskwarren's Avatar
    For those of you with a Note 7 made just before the recall make sure you have plenty of documentation to prove that your phone was a part of the safe batch.
    If I were buying a used Note 7 and I saw an August build date, I would avoid buying that phone as I would not be comfortable knowing if it was an unreturned recalled device or not.
    09-16-2016 09:50 AM
  4. Mahdi Marmouz's Avatar
    it's hard to say, I see a small imperfection on top left side corner, but ... not sure ... it's clean the back tho .. but for sure the plastic was not done properly ! dust behind and it was not clean, but after a clean up, it's as new ..
    09-16-2016 10:34 AM
  5. Mahdi Marmouz's Avatar
    damn, I had to go over the restore again, it was like a factory reset !
    09-16-2016 10:36 AM
  6. donm527's Avatar
    I imagine if they did it will be ok. Like Apple stores they have machine that helps them automate the opening process for replacing batteries onsite, they probably do it by machine and it re-closes. They'd have to ya think to reapply the seal properly for water tight seal.
    09-16-2016 11:14 AM
  7. Morgothor's Avatar
    Born and raised in Quebec City
    09-16-2016 11:29 AM
  8. marzfreerider's Avatar
    Just got my shipping notification for delivery on Monday September 19. I'm in BC.
    cynth.hgn likes this.
    09-16-2016 01:19 PM
  9. Hunan's Avatar
    All the phones that have been returned can be refurbished.
    09-16-2016 01:22 PM
  10. stmax's Avatar
    Boy still no email from Stericycle. They better not be closed over the weekend with this going on.
    09-17-2016 04:55 PM
85 ... 234
  1. S Note app for Galaxy Note 7
    Last Post: 09-21-2016, 12:34 PM
  2. Departed the Note 7 for an Edge today!
    By Blues Fan in forum Samsung Galaxy S7 edge
    Last Post: 09-15-2016, 03:38 PM
  3. Replies: 1
    Last Post: 09-14-2016, 08:04 PM
  4. Replies: 2
    Last Post: 09-14-2016, 06:22 PM
  5. Note 5 video playback issue
    Last Post: 09-14-2016, 04:23 PM
