1. Blazeeofglory's Avatar
    Hi everyone!
    My small gearfit 2 FINALLY shipped after being "in route" since the 22nd. I have 2 quick questions. 1) Can you use the gps to track a run without your phone on you? And 2) can you receive notifications from your phone if its not on you? (Assuming not...bluetooth correct?) Sorry..never owned a fitness watch before and was mainly curious about the gps.
    Thanks!
    09-14-2016 10:29 PM
  2. Strong_Genetics's Avatar
    Hi everyone!
    Thanks!
    1: Yes cause it has built in GPS
    2: Not really it connects to bluetooth and if ur out of range of Bluetooth it will connect to WiFi but I'm not sure if it still communicates with the phone over WiFi or just uses it to load weather etc etc...but u definitely cant leave ur phone at home and still get notifications if that's what ur asking....It's not a true smart watch so it's still kinda tethered to ur phone for most features
    09-14-2016 10:34 PM
  3. NotAnAppleGuy's Avatar
    Funny thing is mine just shipped also lol.
    09-15-2016 07:15 AM
  4. jinxygrrl's Avatar
    Me too. I woke up to an email from Samsung saying that is finally shipped.
    09-15-2016 07:22 AM
  5. billykac's Avatar
    Here's a good place for Fit 2 info.
    Samsung Gear Fit 1 & 2 - Android Forums at AndroidCentral.com
    I love mine!
    09-15-2016 07:40 AM
  6. LegalAmerican's Avatar
    Just a heads up, I absolutely LOVE my Gear FIt 2 and have worn it nearly every day since I got it last month. However, I've noticed a pretty large drain on my phone battery while using it. My Note 7 would be at about 69% at the end of the day before I got my Fit 2, and after I connected it I lose about 20% more battery.
    Then I went and traded my Note under the recall for the temporary S7 edge, and the S7 edge had the same exact thing happen. It was great on battery until I connected it to my Fit 2 and now it loses about the same 20% extra that the Note did.
    09-15-2016 09:08 AM
  7. dzstoys's Avatar
    I really wanted to like this device, but the only good thing I can say about my Gear Fit 2 is that it can control Spotify.
    I have been wearing it daily for the last 3 weeks and the step count for me is between 1,000 and 2,000 low as compared to my old FitBit and a standard pedometer (I average around 10,000 steps a day). I climb 10-20 flights of stairs a day and the Gear Fit 2 has only registered 3 flights in the last 2 weeks. I have replaced it twice at Best Buy with the same results.
    I think this could probably be fixed with a software update, but I think Samsung has other things on their mind. For now, mine is sitting on my desk at home and I am back to FitBit.
    I guess there is one other good thing I can say - it was worth the price I paid for it since it was free.
    09-15-2016 09:32 AM
  8. LegalAmerican's Avatar
    I've had the same issue with the floor counter. One day it will credit me with 4 flights of stairs, and other days 0. Even though I climb the same set of stairs multiple times every single day at work.
    09-15-2016 09:35 AM
  9. toenail_flicker's Avatar
    Does it at least offer a way to up the count for steps that are missing?
    09-15-2016 09:40 AM
  10. dzstoys's Avatar
    No, you can add cups of coffee and cups of water, but not flights of stairs.
    09-15-2016 09:41 AM
  11. dzstoys's Avatar
    It is a great looking device, fits nicely on the wrist but it is not very accurate.
    09-15-2016 09:41 AM
  12. toenail_flicker's Avatar
    Even my Misfit allows you to adjust and it's just about the worst wannabe fitness tracker you can find.
    09-15-2016 09:42 AM
  1. Google Fit data sync
    By Bart Childers in forum LG Watch Urbane 2nd Edition
    Last Post: 12-16-2016, 03:06 AM
  2. Replies: 7
    Last Post: 09-26-2016, 12:54 PM
  3. Questionable folder in storage\emulated\0
    Last Post: 09-14-2016, 02:01 PM
  4. LG Escape 2 bluetooth compatibility question
    Last Post: 09-14-2016, 12:27 PM
  5. Samsung s7 edge & gear vr promo
    By bettyn100 in forum Samsung Galaxy S7 edge
    Last Post: 09-13-2016, 07:44 PM
