1. Tahir27's Avatar
    I just purchased a Samsung Wireless fast charging pad, but when I try to use it, I get a message saying that the wireless charging has paused a few seconds after I place the phone on the charger. Has anyone else had this problem and has found a solution?
    09-22-2016 07:08 AM
  2. dsignori's Avatar
    Yes. This is a fairly common issue. I ended up using different fast wireless chargers. What you describe happened to me consistently with the Samsung Fast Wireless charger using my Note 7 , and my Note 5.
    Get a few of these. They are 1/2 the price, and work great (you will need to use your own fast charging plug with them - doesn't come with one)
    Netguysc likes this.
    09-22-2016 07:29 AM
  3. Tahir27's Avatar
    Alright, thank you. I guess I will return this one and try that one.
    09-22-2016 08:18 AM
  4. Blazeeofglory's Avatar
    I had this issue. It would start flashing and stop charging after a few seconds. All I did was plug the charger into a different outlet and it has been flawless since.
    09-22-2016 09:21 AM
  5. chazglenn3's Avatar
    Try using a different USB cable if you have another one.
    09-22-2016 09:28 PM
  6. Dubss's Avatar
    I haven't had any issues with my fast charger
    kevinpleasants likes this.
    09-22-2016 10:03 PM
  7. Gsxr151's Avatar
    Do you have a case with any metal or metallic paint?
    09-22-2016 11:04 PM
  1. wireless charging, all about
    By bialy in forum Samsung Galaxy S7 edge
    Last Post: 03-04-2017, 09:07 AM
  2. Samsung Galaxy tab A with S pen 2016
    By Walter Turns in forum Samsung Galaxy Note Pro 12.2
    Last Post: 11-20-2016, 05:01 AM
  3. Pairing Jabra with Samsung
    Last Post: 09-29-2016, 04:00 AM
  4. Replies: 0
    Last Post: 09-22-2016, 05:14 AM
  5. Replies: 1
    Last Post: 09-21-2016, 10:30 PM
