10-12-2016 07:00 AM
133 ... 23456
tools
  1. shaleem's Avatar
    Anyone else noticed that the note 7 screen is on yellowish side!
    I compared it with the s7 and s7 screen is much nicer and whiter!
    No, I haven't noticed that at all.
    Viscomi4444 likes this.
    09-23-2016 09:23 PM
  2. lanenubia's Avatar
    Maybe check your Display settings and make sure that the Blue Light Filter is turned OFF. That turns the screen yellow, if it is ON.
    jamesrick80 and Jewels81 like this.
    09-23-2016 09:52 PM
  3. Matt_james_matt's Avatar
    Anyone else notice that they cheapened the sim/sd tray? It was metal on my 1st note, now its flimsy plastic. Not a big deal, but something I noticed right away.
    I noticed this to I didn't notice was it was I didn't really pay attention to first sim tray but I noticed something was defiantly different taking it out and putting it if was a lot more of an effort and it was sorta flimsy maybe tighter fit helps with water proofing the sim tray better then previously idk
    09-24-2016 08:04 AM
  4. Matt_james_matt's Avatar
    do you know what I did notice mine was idk if it was just cause I was using a crappy phone for 2 weeks and the vividness of the note 7 was a lot better but I noticed this a lot on the emojis go have a look at the emojis and tell me what you think
    09-24-2016 08:07 AM
  5. juliesdroidsync's Avatar
    I was just about to ditch/return the Note 7 and go with the Iphone 7 plus. The Iphone was back ordered until mid to late October. So the dilemma was to stay with the Note 7 or switch. Yesterday morning, I received an update on my old Note 7 and everything was a bit more snappier, less lag etc..I decided why not, I'll get the new replacement Note 7, if it still having all these issues I was having, I'll JUMP into the Iphone 7.
    OMG, what a big difference it is from my old Note. Everything is snappier, no lag, it feels so much more optimized. This is what the NOTE 7 shoulda been when it first came out.
    I'm so happy I stuck with the Note 7. Is everyone having the same experience as I am?
    Yes, I thought maybe I was imagining things,but... I loved my <now returned> Silver Sizzler, but I REALLY love my new GN7!
    Since I have around 175 apps total installed (yes, I actually use all of them, at least from time to time...) the one place I can go to look for any kind of a "lag" is in the Application Manager. Once there, if you try to scroll as fast as you can, if your phone has any lag for any reason, this is where I've always been able to see it.
    On the new GN7, there is no lag whatsoever.
    Best. Phone. Ever.
    09-24-2016 08:14 AM
  6. RobertP1's Avatar
    I had my T-Mobile Note 7 and exchanged it for a SG7E and glad I did it. I am not concerned about the safety issue, I just wasn't an S-PEN guy. The SG7E is amazing and I don't see the Note 7 being worth it, unless you are a S-PEN person. I got my phone and a few bucks back.
    09-24-2016 09:48 AM
  7. shaleem's Avatar
    I had the SG7E as a loaner and I was very impressed with that phone. I loved everything about it except for the fact that there was no S Pen. I do use it, so I went back to the Note 7.
    RobertP1 and Iconic_Vixen like this.
    09-24-2016 10:00 AM
  8. wboyce58's Avatar
    Yes, I really think they tuned the replacements. My green Note7 is definitely snappier and smoother than my original one.
    Green?
    09-24-2016 10:01 AM
  9. RobertP1's Avatar
    I would go back also if I used the S-Pen often
    09-24-2016 10:02 AM
  10. Wiley_11's Avatar
    Green?
    The battery icon is green on the replacement Note 7 instead of default white.
    09-24-2016 10:21 AM
  11. wookiee2cu's Avatar
    Mine does seem a little snappier. With my first one I did a smart switch with a cable linking the Note 7 to my Note 5. I never really noticed any lag issues except for scrolling in Facebook but just assumed it was the app. With the replacement, I backed up my old Note 7 to my computer through the Smart Switch program. With the new phone I hooked it up to my computer and did a restore through the Smart Switch program, this is the only only thing I changed when setting it up. Now when in the Facebook app it scrolls much more smoothly but this could have been an update to the app, who knows. One thing I also noticed, unlocking my phone with my fingerprint is way faster. To the point where I thought the fingerprint unlock wasn't set up until I tried using a different finger then the one I scanned. All in all it's running great, stoked to have my Note 7 back, the S7 loaner was a huge downgrade.
    jlczl likes this.
    09-24-2016 11:42 AM
  12. anon(607340)'s Avatar
    My original Note 7 (which was FLAWLESS btw) was the cool blue, bright white... replacement is the yellow white. At first this infuriated me, but I've gotten used to it. You're right though.
    09-24-2016 11:45 AM
  13. delco714's Avatar
    I love mine. I just discovered that the iris scanner works through my sunglasses. It didn't do that for me before.
    Not new
    09-24-2016 01:27 PM
  14. skatergirl's Avatar
    My themes were not on the theme store and I had to search and download them again. Was this update recent?
    Go to Samsung Themes and look for My Page. Then log in. That is where I found all my purchased and non purchased themes.
    fitcherama likes this.
    09-24-2016 03:47 PM
  15. skatergirl's Avatar
    Now, why would I want to replace my replacement? It is working beautifully. I don't want to go through all that stuff again.
    I am trying all kinds of things with my battery to make sure I have one that will give me a lot of time because no, I cannot imagine having to go through setting up one more phone right now.
    French likes this.
    09-24-2016 03:49 PM
  16. delco714's Avatar
    No one commented on my question..My aftermarket micro USB cable using the included converter to C no longer fast charges this phone as my previous 7 had.. Thoughts?
    09-24-2016 08:57 PM
  17. rushmore's Avatar
    Still not seeing how the battery life has gotten better and the performance is even faster. I was happy with my first Note 7, so was not expecting much of a ceiling increase if any.
    Battery life is about 20% better (was already good for me)
    Dead or Alive Plus is an arcade game on MAME that I use to test CPU power for devices. It went from barely being faster with frame rate than the MXPE (808 chip) to 30% faster. That is huge for MAME.
    I normally do not rave, but the Note 7 went from great to even greater. Glad I stuck with the Note 7.
    09-25-2016 12:12 AM
  18. rushmore's Avatar
    Could be part of the firmware update and is more strict now on power thresholds. If the charger and cable that came with the N7 works, that is probably the issue.
    amyf27 likes this.
    09-25-2016 12:14 AM
  19. stackberry369's Avatar
    Why didn't you just hold out for the S8? It's going to be even more powerful than the S7
    amyf27 and RobertP1 like this.
    09-25-2016 03:57 AM
  20. climb's Avatar
    Agree with everyone else. My new Note 7 replacement is simply awesome. It is so much more responsive and the battery life is better than before.
    I loved my Note 7 version 1.0 and I love version 2.0 even better.
    The screen is gorgeous, battery life seems as good if not better, the responsiveness is wonderful, and I've even gotten to like the green battery indicator.
    For my purposes, the business functionality, split screen and S pen are incredible.
    IMHO there is not another flagship out there as feature rich.
    Loving my sleek dark black Note 7 !!!
    mikechaudron likes this.
    09-25-2016 09:08 AM
  21. amyf27's Avatar
    I went into a video store and paid with my phone-they had this small little card reader by their pc screen and it worked. Loving that.
    09-25-2016 04:22 PM
  22. Ca_lvn's Avatar
    I went into a video store and paid with my phone-they had this small little card reader by their pc screen and it worked. Loving that.https://uploads.tapatalk-cdn.com/2016...53fd8572b9.jpg
    Yep SP works on almost every magnetic card reader one of my favorate features, did run into a problem returning sothing, seems the registers are a bit confused returning with SP
    09-25-2016 06:25 PM
  23. amyf27's Avatar
    The only one it didn't work on was electronic dept at a walmart. Could have been the sales clerk though. At any rate it's awesome
    09-25-2016 06:27 PM
  24. Ca_lvn's Avatar
    And hopefully as advertised more secure with a digital card instead of my actuall card being used.
    I had a issue at Wal-Mart it was the girl I asked for the manager and it processed no problem that was with a gift card loaded in.
    amyf27 likes this.
    09-25-2016 06:30 PM
  25. amyf27's Avatar
    The girl at the video store that worked there she was absolutely floored that that worked. I get a big kick out of surprising cashiers with the Samsung Pay
    09-25-2016 06:33 PM
133 ... 23456
  1. Why are Gmail emails not syncing to my Samsung galaxy s3
    By JamesCAllen in forum Ask a Question
    Last Post: 09-29-2016, 04:04 AM
  2. Replies: 1
  3. When will the Note 7 be available for purchase in Canada?
    By Sailor Webber in forum Samsung Galaxy Note 7
    Last Post: 09-23-2016, 10:29 AM
  4. Why don't does my phone not have enough storage as it should?
    Last Post: 09-22-2016, 12:07 PM
  5. Where did my apps go?
    Last Post: 09-22-2016, 09:10 AM
