1. cerberus0820's Avatar
    I have used many times the feature where you can pull the spen out, and write a note and pin to the AOD. However, is it possible to write a note in the Samsung Notes app, and then pin to the AOD display after you've saved it? I can't seem to find that as an option - but it should be!
    09-22-2016 06:49 PM
  2. russel5150's Avatar
    Its not an option, but i agree it is a good idea.
    As soon as the recall stuff us done we can go back to screaming we want action memos back, i miss that!!
    As of now i am using the widget to keep temporary lists and stuff on a home screen.. not as good as pinning an action memo to the hm screen.
    09-23-2016 08:07 AM
  3. Modi N's Avatar
    It is possible in some extent..
    Write note in Samsung Notes > Save
    Share> Image> Always on Display.
    Your note will be shown there as an image for 10 mins.
    After 10 mins it will be minimized same as any other note.
    Remember this is a image so you can not edit it. You can again edit in Samsung Notes and save.. follow same steps to get updated note on AOD.
    10-03-2017 03:19 PM
  1. Are we alowed to discuss jailbreaking note 4's?
    By PedgeJameson in forum Samsung Galaxy Note 4
    Last Post: 09-24-2016, 12:29 PM
  2. How can I get my earbuds to work on my Samsung cell phone?
    Last Post: 09-23-2016, 08:26 AM
  3. Samsung Emoji Keyboard search on Note 5
    Last Post: 09-22-2016, 06:46 PM
  4. Replies: 0
    Last Post: 09-22-2016, 06:38 PM
  5. Replies: 0
    Last Post: 09-22-2016, 06:20 PM
