1. anon(10029905)'s Avatar
    For some reason samsung account is not uploading or syncing my s notes... I really want my notes before i exchange my phone tomorrow!
    09-22-2016 08:08 PM
  2. Sam_Gs7's Avatar
    Welcome @Pato89: What I'd do in your case is Goto your Phone-Carrier
    and request Data transfer, like they do with the Contacts when we
    buy a new phone, but you need another Phn. Also in Phone
    repair shops, can be fixed too..SeeYou!
    09-22-2016 08:30 PM
  3. kadinldg's Avatar
    Can you move them to an SD card or over to a computer?
    09-22-2016 08:59 PM
  4. jamesrick80's Avatar
    The reason why i prefer google keep for notes etc...
    09-22-2016 09:28 PM
  5. Skybrok's Avatar
    Mine transferred through smart switch. I saved it/them to the sd card before I swapped phones and everything, including my setup on the previous phone switched over.
    09-23-2016 02:34 AM
  6. anon(10029905)'s Avatar
    How did you transfer it to SD card?
    Got some reason I can't find the note file in my file!
    09-23-2016 07:07 AM
  7. anon(10029905)'s Avatar
    How do you use Google to save notes?
    09-23-2016 07:08 AM
  8. kadinldg's Avatar
    Go into S Note, select all your notes you want to save, then select "Share". Select file type as S Note and then you will be shown all your options of apps to share to. Select Google Drive.
    dsignori likes this.
    09-23-2016 08:08 AM
  9. Skybrok's Avatar
    Go to settings> backup and reset> open smart switch> menu in top right corner> select -transfer via external storage
    09-23-2016 09:50 AM
  10. Skybrok's Avatar
    Hope that helps
    09-23-2016 09:51 AM
  11. audri5's Avatar
    Phone carriers are not allowed to do this with the Note 7. All recalled phones have to be powered down upon entering the store and data can not be transfered in store due to chance of the phone exploding or catching fire.
    09-23-2016 09:52 AM
  12. alwilliam's Avatar
    Depends. The Tmo store I went to were doing file transfers when I exchange my Note. Nobody yelled at me either for still using the old Note 7 when I went there.
    09-23-2016 11:09 AM
  1. I need HELP please
    By wezi427 in forum Google Nexus 5
    Last Post: 09-24-2016, 11:09 PM
  2. please recover my photos I accidentally deleted yesterday
    Last Post: 09-22-2016, 04:53 PM
  3. Replies: 1
    Last Post: 09-22-2016, 03:48 PM
  4. Samsung cloud.. Need help please!
    By Pato89 in forum Samsung Galaxy Note 7
    Last Post: 09-22-2016, 01:11 PM
  5. need help :/
    By samrakhan in forum Ask a Question
    Last Post: 09-22-2016, 10:01 AM
