1. note7s7edge's Avatar
    I got my new Note 7 after giving back the S7edge I got as a loaner and tried to restore the apps I had backed up into samsung from my previous dangerous Note 7. However, I keep getting this error:
    Failed to restore:
    A network error has occurred.
    Some data is missing. To
    prevent losing the missing data
    permanently, try restoring your data
    again before backing up.
    09-23-2016 06:46 PM
  2. russel5150's Avatar
    Nothing is showing up.
    I finally quit using the verizon cloud and back up my contacts just to my google. Not sure but think you can back up app data too. It is so much easier and now i disable verizon cloud as soon as i get s new phone. You might consider that if it is an option.
    09-23-2016 06:49 PM
  3. emcknight23's Avatar
    had the same issue. I figured out to restore them separately. Worked for me to restore each option one at a time. i saved homescreen and Apps last. those two you have to do at the same time. Only way i could get it to work without failing
    09-23-2016 09:08 PM
  4. note7s7edge's Avatar
    That tip worked actually. Thanks
    09-24-2016 09:50 AM
  1. Extracting Audio From Webpage Android
    By altobobcat in forum Nexus 5X
    Last Post: 09-28-2016, 06:58 AM
  2. Samsung Note 7 recall info
    By Dirtymark in forum Samsung Galaxy Note 7
    Last Post: 09-25-2016, 07:42 AM
  3. IMEI problem - LG G3 d582
    By aspergerian in forum General Help and How To
    Last Post: 09-24-2016, 08:55 PM
  4. Anyone else's Samsung Pay Not Working Recently?
    By djlee0314 in forum Samsung Galaxy Note 7
    Last Post: 09-24-2016, 04:07 PM
  5. Problem with Gmail's push notifications!
    By freeideasguy in forum Samsung Galaxy Note 7
    Last Post: 09-23-2016, 08:51 PM
