Note 7 Battery Draining Too Fast
I have one of the replaced Note 7s. I have noticed my battery draining WAY fast. As an example, this morning, I turned it on (after a full charge) about 35 minutes ago. I am now at 83%. I have done next to nothing with the phone since turning it on--I checked a text. I also closed ALL applications that were running.
This was a problem with the first Note 7--you know, the kind that might have exploded--and I couldn't figure it out then.
When I check the battery usage, it usually shows Android System then Andoid OS. Right now, it lists T-Mobile as the most-used app for battery. First time I have seen T-Mobile up there.
What can I do to figure out what's draining the battery so fast? It's quite frustrating.
