Software optimizations can enhance battery life and that's what they did.....3500mah is 3500mah. Unless Samsung performed some undercover OS optimization, the battery life is the same.
Same here, I believe that with the update, they did optimize the battery usage.Mine has been crazy good. I got from 6 this morning until 7 tonight with pretty heavy usage, wifi in and still had 30% left. When I checked on battery usage it said I had screen usage of 6.5 hours.
Battery life on new one is a lot better than the previous so called defective phone. I can go a whole day on one charge with heavy usage now. Also the update was around 460mb and I'm on AT&T. It wasn't no small update. Took white a while to download and update.
I think it's the new green battery as it's more environmentally friendly so it must use less power.
Good one! Next update will have a mini windmill
Or, unless the defect in the original batteries manifested itself in other ways besides simply bursting into flames...?
