Originally Posted by
skatergirl Mine is not good at all. I am disappointed. If it continues this way I will have to have this one replaced as well, though I do not like the idea of customizing another phone.
I think I saw a post where you said you did a smart switch. I hate to say this but I'm in the camp that a clean, like new install is the best way to go. I did smart switch w Galaxy s7 to Note and was experiencing minor annoyances. I then fdr and set up from scratch...all the annoyances went away.
I realize that was an S7 to Note...but I decided to set the new Note up from scratch as well. The only issue I had was not getting the tone when using the "ok Google" command but rolling back the Google app one update seems to have fixed it. I also appear to be running the beta of Google so that might have to blame as well.
As far as battery life goes, I feel I've barely put mine down since getting it so I STILL don't know what a real day would be like but it definitely has the same if not better battery life. No complaints here.
