09-29-2016 01:22 PM
57 123
tools
  1. dlgus's Avatar
    I believe it's suppose to be 4 hours after no use and smart lock locks up and asks for a pin again.
    I actually got a note telling me that...my phone is set to stay unlocked while near my gear2...but after 4 hours....
    09-27-2016 03:19 PM
  2. Bbarbie's Avatar
    My phone used to lock after not being used and then ask for fingerprint but ever since I set up my new fitbit it won't lock at all... I use Samsung s view case and it locked before but not now. What is causing this ?
    09-28-2016 09:55 AM
  3. Snareman's Avatar
    Did you set up the fitbit as a "safe connection" or whatever its called where the phone won't lock while connected to it? Turn off the FB or disconnect it from the phone and see if it locks then.
    09-28-2016 10:52 AM
  4. Bbarbie's Avatar
    Yes i had done safe connection. Thank you so much i will try to disconnect and reconnect
    09-28-2016 11:41 AM
  5. Bbarbie's Avatar
    Thanks again your trick helped solve my issue. I wonder if the always open when fitbit is around setting caused battery to drain ? Because before that i had no issues with battery loss. I shall observe how it works now that I fixed the issue. Thanks again.
    09-28-2016 12:45 PM
  6. Snareman's Avatar
    Glad it worked. Not sure about the FB. You could take it away and see if it changes things.
    Bbarbie likes this.
    09-29-2016 01:00 PM
  7. Bbarbie's Avatar
    Thanks again, yeah mow everything has been resolved and battery also is not draining.
    09-29-2016 01:22 PM
57 123
  1. What Will It Take For The Ban Of The Note 7 To Be Lifted?
    By Bartone in forum Samsung Galaxy Note 7
    Last Post: 09-30-2016, 12:23 PM
  2. How to change the screen over lock screen
    By AC Question in forum Samsung Galaxy S7
    Last Post: 09-27-2016, 06:03 AM
  3. Audio Settings for headphone jack
    By homer813 in forum Samsung Galaxy Note 7
    Last Post: 09-26-2016, 12:13 AM
  4. Best Way To Back Up for Replacement
    By komobu in forum Samsung Galaxy Note 7
    Last Post: 09-24-2016, 03:52 PM
  5. Replies: 0
    Last Post: 09-24-2016, 01:12 PM
