I just sent developer an email and link to this forum. Will see what happens.Let me know if either of you figure something out. Usually I'm the odd man out. Maybe refer the Nova guy to this thread so he can see the differences?
I'm also assuming everyone is using a note 7 also.Let me know if either of you figure something out. Usually I'm the odd man out. Maybe refer the Nova guy to this thread so he can see the differences?
I got a reply from the developer. Here it is, I now have it and double tap for screen off and using fingerprint to unlock is working.Let me know if either of you figure something out. Usually I'm the odd man out. Maybe refer the Nova guy to this thread so he can see the differences?
Yep. I have prime too. Weird. Oh well thanks for heads up. I'll keep trying.
I use mine every day. Swipe up, swipe down, double tap. They work just fine.nova gestures wont work. sorry
Some hereI use mine every day. Swipe up, swipe down, double tap. They work just fine.
I believe it's suppose to be 4 hours after no use and smart lock locks up and asks for a pin again.
My phone used to lock after not being used and then ask for fingerprint but ever since I set up my new fitbit it won't lock at all... I use Samsung s view case and it locked before but not now. What is causing this ?
Thanks again your trick helped solve my issue. I wonder if the always open when fitbit is around setting caused battery to drain ? Because before that i had no issues with battery loss. I shall observe how it works now that I fixed the issue. Thanks again.
