1. Joeykool's Avatar
    I'm guessing not but thought I'd ask.
    Screen protector I thought might fit face without curves?
    09-27-2016 10:31 PM
  2. SpookDroid's Avatar
    That's a no. Cut-outs wouldn't align, either.
    09-27-2016 11:00 PM
  3. Joeykool's Avatar
    I figured a much.... What about a flat screen protector?
    09-27-2016 11:12 PM
  4. trucksmoveamerica#AC's Avatar
    No, I was at a Verizon store and we tried, to wide..
    I have this one coming, says it is flat and won't cover the edges.
    https://www.amazon.com/gp/aw/d/B01KE...cUvbUpU5451622
    09-28-2016 07:23 AM
  5. Joeykool's Avatar
    Thank you
    09-28-2016 09:28 AM
  6. SpookDroid's Avatar
    Like the other poster said, it's just not the right size. Unless you can find a flat protector without cutouts that only fits the screen (which would be for any other kind of smaller phone) then it just won't fit.
    09-28-2016 11:08 AM
  7. Joeykool's Avatar
    Thanks, I'm just going to use one of my v10 screen protector and cut it till I find one I like. These curved edges seem to cause issues. I will probably stay with a flat face only protector. I hope that is a good idea... What do you think?
    09-28-2016 11:15 AM
  8. SpookDroid's Avatar
    It won't be ideal, but not terrible. As long as you can keep as much of the flat portion covered, a case should help keep scratches away from the curves.
    09-28-2016 11:45 AM
  9. Joeykool's Avatar
    Thank you
    09-28-2016 11:45 AM
  10. SpookDroid's Avatar
    Thank you
    I've used IQ Shield's 'case friendly' protectors and that's exactly what they do: cut off SOME of the edges (it still curves a bit) so that they don't touch case edges. It leaves a little of the screen unprotected, but it helps with peeling off from friction.
    Joeykool likes this.
    09-28-2016 11:49 AM
  1. Replies: 1
    Last Post: 11-05-2016, 02:48 AM
  2. New Replacement Safe Note 7 catches fire and explodes in China
    By catloverplayer in forum Samsung Galaxy Note 7
    Last Post: 10-04-2016, 09:19 AM
  3. Samsung Galaxy Note 4 (SM-N910T)
    By Clayton Olson in forum Samsung Galaxy Note 4
    Last Post: 10-01-2016, 02:38 AM
  4. Phone – oneplus 2 - Screen Software Issue
    Last Post: 09-27-2016, 10:00 PM
  5. Replies: 0
    Last Post: 09-27-2016, 08:45 PM
