Save big + get 3 months free! Sign up for ExpressVPN today
  1. freeideasguy's Avatar
    Got my replacement and did the update and for many days everything was working amazing well. Phone won't overheat anymore and battery was significant better.
    All of the sudden this morning and without performing any update or anything related the settings under the "update' section of the phone look different and also when I press to manually update etc nothing happens (see attached pic)
    Also battery all of the sudden is dropping like crazy. I haven't installed any weird app etc.
    Anyone has experiencing the same issue?
    Big thanks all!
    F.
    All of the sudden "updates" section is different + battery problem!-screenshot_20160929-115542.jpg
    09-29-2016 12:37 PM
  2. B. Diddy's Avatar
    Have you already tried wiping the cache partition? https://support.t-mobile.com/docs/DOC-26610
    09-29-2016 12:56 PM
  3. freeideasguy's Avatar
    thanks. did that. still the same. very weird. all of the sudden battery drops like crazy
    09-29-2016 01:40 PM
  4. B. Diddy's Avatar
    How about in Safe Mode? https://support.t-mobile.com/docs/DOC-26624
    09-29-2016 02:48 PM
  5. jerrycau123's Avatar
    Same issues
    09-30-2016 01:05 AM
  6. jerrycau123's Avatar
    And my phone is overheating
    09-30-2016 01:14 AM
  7. TheSpiderX's Avatar
    Weird I was coming to find if someone was having this problem as well or I'm crazy. This is still on my original because I haven't gotten my replacement yet, but all of a sudden today programs like Whatsapp and Facebook are showing notifications that aren't there and the battery life is abysmal all of a sudden. I had it charged to 100 and now it's at 86 with me literally not touching it at all and nothing is running. This is crazy.
    09-30-2016 01:28 AM
  8. hasasimo's Avatar
    You guys may be having the same problem as some S7 users in this thread: http://forums.androidcentral.com/sam...ml#post5454178
    09-30-2016 02:20 AM
  9. jerrycau123's Avatar
    I reported last night that I was having similar issues... TODAY, all seems fine.. I keep rebooted my phone and that seemed to help... Also, I had an issue with changing my phone, but I discovered this was from a bad outlet!..
    09-30-2016 09:30 AM
  10. j_hansen's Avatar
    have you the VR app installed, if so, uninstall it for now, apparently it is an update to that causing the battery drain issue
    B. Diddy likes this.
    09-30-2016 09:58 AM
  11. B. Diddy's Avatar
    Yep, here's a story about it: Latest Oculus VR update linked to heavy battery drain on Samsung phones - Android Authority. But that wouldn't have anything to do with the different system update menu mentioned in the OP, would it?
    09-30-2016 10:56 PM
  12. jerrycau123's Avatar
    After the Oucules downloads and its issues, my phone is back to normal!.
    Oucules stated that you don't need to Uninstall there apps. Fixing the issues!
    10-01-2016 01:23 AM
  13. HOLLYWOODANT215's Avatar
    This is killing my battery
    Attached Thumbnails All of the sudden "updates" section is different + battery problem!-3259.jpg
    10-01-2016 03:37 PM
  14. HOLLYWOODANT215's Avatar
    Crazy
    Attached Thumbnails All of the sudden "updates" section is different + battery problem!-3258.jpg
    10-01-2016 03:38 PM
  1. Replies: 5
    Last Post: 11-02-2017, 01:56 PM
  2. S7 Battery at 54% in less than four hours
    By Yardstick in forum Samsung Galaxy S7
    Last Post: 11-14-2016, 12:29 AM
  3. My battery life is rubbish?
    By dj1891 in forum Samsung Galaxy S7
    Last Post: 10-02-2016, 12:26 PM
  4. is it really worth not getting a note 7 over another phone?
    By Joeykool in forum Samsung Galaxy Note 7
    Last Post: 10-02-2016, 02:09 AM
