1. jj2339's Avatar
    So I had the note 7 on launch day and loved it, but the size was difficult when I went for a jog or mountain biking. Given some of the issues with the glass cracking or scratching I'm a little concerned to have it in zippered shorts when I bike, and could fall out of pocket if I'm running. I returned it during the recall, but want to rebut it now that it seems to be fixed.
    What are you guys doing for working out with it, the phone is rather massive, The armband is ridiculously big, so not an option. Some mentioned a smart watch to put tunes on, but having a hard time finding a watch right now that meets what I want (gear s3 looks great but no google play music app). I love the idea, and it's finally a use case for a smart watch that would work for me, but probably need to wait a bit until what I want is on the market.
    Found something called a flipbelt that looked interesting. Waist pouch that is NOT a fanny pack that holds things tight to your waist. Not waterproof, but the phone is, so that's no issue. Anyone use one, and does the note 7 work fine? Won't cause scratches? And sad to say, with the battery issues, I am slightly worried to have it tied to my waist like that in a tight Lycra band...
    09-30-2016 08:48 AM
  2. pinhunter27's Avatar
    I have a flip belt that I've used with my S5. I haven't tried it with the note 7 ... took a break from running. But planning on giving it a go tomorrow. I'm a little worried about the size. I'll let you know..
    09-30-2016 09:45 AM
  3. lv2bsilly's Avatar
    I tried it and I didn't like it. I felt like the belt itself rides up and its not as convenient when you take your phone in and out of it. I prefer the Spiebelt. It's a zippered pouch, but it lays flat against you and doesn't bounce too much when you run. It is a lot easier to get your phone in/out of it too.
    jj2339 and Serkle K like this.
    09-30-2016 10:04 AM
  4. jj2339's Avatar
    Thanks! I'll try that, worried it was a bit fanny pack, but hearing a real person rate it makes me feel better!
    You think that would also work for biking? Perhaps rotate it so it rides on my back?
    09-30-2016 10:56 AM
  5. pinkvikchick's Avatar
    I'm 5-3 and a runner- I use an arm band. I tried the flip belt as well, same, it slides and bounces.
    I bought an iPhone 6plus sized arm band back when I was on the plus, it fit my Note 5, A Huawei Mate 8, the edge and Note 7. Maybe I'm just used to it but it doesn't bother me at all. Maybe just buy a cheapy guy on amazon and try it out.
    09-30-2016 11:36 AM
  6. Serkle K's Avatar
    I second the spibelt. They now make different kinds to better suit your workout needs. I haven't tried it yet with the note7, but I used to keep my wallet, house key, and BlackBerry Passport in it, and run. It didn't jump around at all.
    jj2339 likes this.
    09-30-2016 11:55 AM
  7. keepnitreel's Avatar
    I use a armband but I strap it on my left leg, right below the knee/above the calf
    09-30-2016 12:02 PM
  8. amyf27's Avatar
    When I'm on my hybrid bike, I have the Note 7 in a handlebar phone holder for easy access and viewing. When at the gym doing weights, I have it in my Shark magnetic zipper case with Clearview window. I can plop it on the machine while working out and go to each station that way.
    09-30-2016 12:19 PM
  9. lv2bsilly's Avatar
    Yes, you could definitely use it for biking. It is totally adjustable
    jj2339 likes this.
    09-30-2016 01:57 PM
  10. jj2339's Avatar
    Thanks!! I'll give it a try, that flipbelt looked kinda odd to be honest!
    lv2bsilly likes this.
    09-30-2016 03:14 PM
  11. donm527's Avatar
    Running Belt
    I used this belt for years carrying LG G2, G3 and iPhone 6. Run 12-20 miles week on avg. used in races/half marathons. Comfortable.
    jj2339 likes this.
    09-30-2016 10:41 PM
  12. RenoD2010's Avatar
    This is me though I'm 5'9". I don't run but walk using an arm band. I don't love it but it works. Can't wear it when doing weights and machines in the gym but I feel a lot better about putting my phone down inside its case inside the arm band.
    On my bike, it will sit inside a stem cradle (have yet to actually try). Very excited the phone is now rain proof.
    10-01-2016 01:43 PM
  13. ihbsbA's Avatar
    Absolutely LOVE my flip belt.
    10-01-2016 09:44 PM
  1. From Note 5 to Note 8
    By Coconut8469 in forum Samsung Galaxy Note 5
    Last Post: 03-17-2017, 07:16 AM
  2. Need help with S7 "Android System" and top menu overlap
    Last Post: 10-03-2016, 08:50 PM
  3. S Charger Pad Compatible with S7?
    By yobil in forum Samsung Galaxy S7
    Last Post: 09-30-2016, 02:14 PM
  4. Replies: 1
    Last Post: 09-30-2016, 08:09 AM
  5. I think my Samsung Galaxy Note 4 has a virus
    Last Post: 09-30-2016, 07:32 AM
