1. bertsirkin's Avatar
    I've had Nova Prime and TeslaUnread on my Note 5 and now on the Note 7. I never had a problem until I got the replacement Note 7. Now, the "Unread Count Badges" option in Nova is constantly turning off. I'll turn it on, and it will be fine for about a half-day, but then it will turn itself off again. I tried uninstalling TeslaUnread and re-installing it, but it keeps turning itself off.
    Any ideas why?
    10-03-2016 07:44 PM
  2. B. Diddy's Avatar
    Any power-saving modes turned on?
    10-03-2016 09:25 PM
  3. Christine Aflak's Avatar
    Any ideas why?
    Mine's always been like this on any phone I've had.
    10-03-2016 09:26 PM
  4. trucksmoveamerica#AC's Avatar
    Email the developer, I had issues and they replied the same day with an answer.
    10-03-2016 09:36 PM
  5. bertsirkin's Avatar
    I don't have any power-saving modes turned on, but am using "Doze". I turned it off to see if that helps.
    I did find a post that found a solution, but it was for an earlier version of Android, and I can't seem to find App Optimization - here's what the poster indicated to do:
    "Go to settings -> battery -> app optimization -> details -> Nova Launcher -> turned off for"
    unfortunately, doesn't make much sense to me.
    10-03-2016 10:18 PM
  6. bertsirkin's Avatar
    I've gotten to the point where I don't contact app vendors anymore, as most never respond, but I just sent Tesla an email.
    10-03-2016 10:24 PM
  7. trucksmoveamerica#AC's Avatar
    They responded to me, they seem to respond do hopefully they will you. I know that your saying though, a lot don't.
    10-03-2016 10:27 PM
  8. B. Diddy's Avatar
    Battery optimization is Android's own power-saving feature. If battery optimization is turned on for an app, then I think the system is more likely to close it down if it hasn't been opened in the foreground for a while. So it's worth trying that suggestion.
    10-03-2016 10:28 PM
  9. bertsirkin's Avatar
    Well, I finally found it - I think Verizon put it in a different location. From settings, click "Battery Usage" - then from the menu, select "Optimize Battery Usage".
    In my case all optimizations were off, so it doesn't help me.
    What I indicated earlier was that I was using "Doze" - that term is confusing since the Doze that I was using was a stand-alone app in the PlayStore (I've uninstalled it now). Android is also using the term "doze" to mean battery optimizations.
    10-03-2016 10:46 PM
  10. chyeo1979's Avatar
    I have Nova Prime, but not using for a while due to unread badge thing. Any other launchers have support for unread badge natively?
    10-03-2016 10:47 PM
  11. B. Diddy's Avatar
    See if ZenUI Launcher is supported. It's the stock launcher on ASUS Zenfones, and works pretty well in my experience. It supports unread badges, at least for certain apps.
    10-03-2016 10:57 PM
  12. bertsirkin's Avatar
    Well, they got back to me REALLY quickly!
    Here's what they indicated:
    Hello,
    This is a known issue on Samsung devices and you can try this to see if it helps fix the issue.
    There is a new feature added called "app optimization" under Settings -> Battery -> Detail and you need to set TeslaUnread to DO NOT OPTIMIZE
    Once you have that set, it should work properly and stop turning itself off.
    I don't have this turned on, but I was using the stand-along app called DOZE - and that may have been doing it. I'll have to see if it's still a problem tomorrow.
    thanks for all the help!
    10-03-2016 11:06 PM
  13. bertsirkin's Avatar
    I'm really hooked on Nova Prime!
    10-03-2016 11:07 PM
  14. David Stopper's Avatar
    Any ideas why?
    That's funny. My original note 7 was doing that. Now my Replacement note 7 does not.
    10-03-2016 11:13 PM
  15. B. Diddy's Avatar
    Oh yeah, so am I! But I was responding to chyeo1979, who was asking for other alternatives.
    10-03-2016 11:49 PM
  16. antman451's Avatar
    I started a thread about this the other day. On my own, I maybe found a fix: I went into Tesla and made sure I switched all permissions on. That, or some magical combination of everything else I tried, seems to be working.
    B. Diddy likes this.
    10-04-2016 01:39 AM
  1. How do i sync my calendar with my outlook account?
    Last Post: 10-04-2016, 07:00 AM
  2. Replies: 1
    Last Post: 10-03-2016, 10:18 PM
  3. Changing Prime Email on Android Tablet
    By mickeyboat in forum General Help and How To
    Last Post: 10-03-2016, 07:36 PM
  4. Replies: 0
    Last Post: 10-03-2016, 06:41 PM
  5. Replies: 0
    Last Post: 10-03-2016, 06:24 PM
