My first and my replacement have both have been beast. not a hint of lag . Why I'm thinking some are confusing animation with lag
If you've seen any of the N7 lag videos that have been posted, there is no confusion at all. It's definitely lag and not animation when you type and get a very delayed response.
I've been experiencing this issue with my Galaxy S6 Edge Plus for a long while now. I've done a factory reset which didn't fix the issue....
Thanks to all for your posts. Truly excited to get this phone!
"I don't know who your carrier is, but I read somewhere that an AT&T N7 user got support to remote into his phone and found software installation issues they were able to repair and return his N7 to no-lag operation. Maybe you might have luck using that approach with your carrier."
Yea they wont do that. I just tried. They basically told me to do a FDR and that was it. Annoyed
The only issue that I have had with the new note 7 is with the Oucules app, there was a major download and the app went into a bootloop, malfunction, causing my phone to overheat, and charging issues!...This issue was with Oucules, not Samsung, and has been fixed!
I love my new note 7!
Who is your carrier?
My keyboard stays on behind the black screen when i press the sleep button n when i press the home button to draw the pattern to log in the keyboard is still there...The only thing I had lag issues with was the stock keyboard. I would recommend using a third party keyboard and message app. I've been using Fleksy and Textra and have had no issues.
I have no lag whatsoever. When setup the new phone try to set it up as new rather than transferring our restoring from old devices
ATT. Dont really want to do a FDR and re setup the whole phone again
Why don't you go to a store and play with the device and see for yourself if it lags. Many users here have no issues with the device, but it all comes down to what you consider lag.
