Verizon fast car charger
2asdavis
13
Anyone else had problems with Verizon fast car charger? My replacement note 7 charges fine with fast samsung wall charger but will not charge with car charger. Sometimes it will start charging for about 3 seconds then stop.
dant1127
Active member
Sep 28, 2016
25
Verizon has 2 or 3 VZW labeled USB-C car/home chargers. I'm not sure why, exactly, but it may be worth a visit to exchange for a different SKU. There are red tipped chargers and I think 2 SKUs for black tipped.
felloffthetruck
Trusted Member
Mar 31, 2013
8,609
21
38
I have the Verizon fast wall charger and fast car charger, both work phenomenal. These are the more expensive "Red Tip" versions.
I've heard about problems with the cheaper black tip models though.
2asdavis
13
I have the red tipped one it worked great until yesterday afternoon then stopped. The charger has no damage and is still basically brand new
2asdavis
13
Ok I might have figured something out I flipped the type c end over and plugged it in the other way and it started charging fine. That is weird because its supposed to work plugged in either way
felloffthetruck
Trusted Member
Mar 31, 2013
8,609
21
38
Maybe you should exchange it at Verizon. Mine works fine no matter which way it's plugged in. These are the ones I have.
