1. pcbtmr's Avatar
    Has anyone attached a microUSB flash drive to this? I attempted to using the usb-C to micro-usb adapter provided with the phone and the phone never acknowledged connection. Connected the flash drive to the Note4 and it worked instantly.
    Any ideas?
    10-05-2016 06:12 PM
  2. Amele's Avatar
    I had the same ting happen (minus the Note 4). I also had a flash drive that had a usb c end of its own and that one the Note 7 said it was charging but would not acknowledge it as an attached drive.
    10-05-2016 06:25 PM
  3. pcbtmr's Avatar
    Just figured it out! The usb-C to micro-usb is not for this purpose. The usb-C to USB (A?) is the right connector and it snaps into the port. Doesn't work with the case on the phone.
    10-05-2016 06:40 PM
  4. Ca_lvn's Avatar
    Never even thought about this until this post and yes it works
    10-05-2016 06:48 PM
  5. larry1014's Avatar
    It works fine on both my wife and I phones. I do have to remove my thin case but not my wife's case.
    10-05-2016 06:49 PM
  1. Where to buy Nexus 6p in the UK
    By DjuroUK in forum Nexus 6P
    Last Post: 10-05-2016, 06:42 PM
  2. How can i use lg g pad 7.0 to make call?
    Last Post: 10-05-2016, 05:23 PM
  3. Replies: 1
    Last Post: 10-05-2016, 05:21 PM
  4. why can't I copy files to my galaxy S5 from my pc?
    Last Post: 10-05-2016, 04:54 PM
  5. How to ger pass the gmail on a Acatel phone
    Last Post: 10-05-2016, 04:16 PM
