10-14-2016 05:46 AM
34 12
tools
  1. Longhorngary's Avatar
    One of the things I used the S-Pen the most for was screen capture and then making notes on it. Is there any similar type of functionality on the Edge even if you have to use your finger?
    10-11-2016 07:08 AM
  2. PRGDR's Avatar
    I am sure there are apps at the play store for all that... (but I haven't really looked, I use a Note series, pre-7, phone).
    10-11-2016 07:25 AM
  3. Longhorngary's Avatar
    Yeah I upgraded from a Note 4 and am afraid I will really miss that functionality.
    10-11-2016 07:29 AM
  4. jackjack1969's Avatar
    I'm trying make the best of a bad situation here. I wonder, does anyone know for certain if the spen will work on a S7 edge? At least write on the S note app. I know there are after market spen launcher type apps in the play store because I tried them out with my Note 3 and Note 4. Wondering if I could buy a S7 edge, get a case that has a stylus holder for and continue to use it as a homemade Note 7.
    I'm thinking it can but maybe if someone has a s7 edge handy they can try.
    Anyone?
    10-11-2016 01:34 PM
  5. treedabl's Avatar
    Anyone?
    I'm pretty sure that the Note has a digitizer that allows the SPen to work. You can use a regular stylus on the s7 but not the SPen.
    10-11-2016 01:40 PM
  6. jackjack1969's Avatar
    I might not get to use the function of the spen, liked pressing the button to bring up there launcher, but the screen will register the touch of the spen same as a regular stylus wouldn't it?
    10-11-2016 01:45 PM
  7. lizardchest's Avatar
    Just got back from the store exchanging my N7 for an S7E.
    The S Pen did not work as a stylus on the S7E, even to swipe screens or open an app. (I only tested on the Demo S7E, if that makes any difference...)
    keepnitreel likes this.
    10-11-2016 01:54 PM
  8. 21stNow's Avatar
    Not unless Samsung makes a change to the Galaxy S line via a software update (which I don't know to be possible). As far as I know, the decision was intentional from Samsung that the S Pen would not work at all on the Galaxy S line of devices.
    It's possible that Samsung would reconsider this due to the Note 7 reaching EOL earlier than expected, but I don't know if the existing Galaxy S line could be updated via software to allow the use of the S Pen.
    10-11-2016 01:54 PM
  9. jackjack1969's Avatar
    Thanks for trying. I guess I'll have to use a regular stylus
    lizardchest likes this.
    10-11-2016 01:58 PM
  10. keepnitreel's Avatar
    True^^^
    I tried using the S-pen on the S7edge loaner and it didn't work at all. My finger nail worked but not the S-pen, SMDH
    10-11-2016 02:03 PM
  11. comestim's Avatar
    The Spen will not work on a capacitive touch screen without hardware support.
    10-11-2016 02:05 PM
  12. jackjack1969's Avatar
    I guess I'll just get a wallet case that has a stylus holder and get the 7 edge. This sucks lol
    10-11-2016 02:08 PM
  13. justin1578's Avatar
    I tried my s pen on a s6 edge and got nothing. I left mine at home when I did my swap anyway. Its mine darn it.
    10-11-2016 02:27 PM
  14. jackjack1969's Avatar
    I'm definitely keeping my headphones in my phone charger
    wcourtois likes this.
    10-11-2016 02:28 PM
  15. crystinonfire's Avatar
    it doesn't work with the S7E, but you can download S-Note from the galaxy app store and order a regular stylus from anywhere and it works. this is what i have done and i'm super happy.
    10-11-2016 05:12 PM
  16. jamesrick80's Avatar
    10-11-2016 08:53 PM
  17. Delirious D's Avatar
    deleted
    10-12-2016 01:11 AM
  18. Delirious D's Avatar
    no but the LG stylo 2 does have it.
    specs are no where near the note 7 though. but its a good alternative until the note 8. thats what ima end up doing. returning this edge7 which im not liking (will post why in another place). Going to return it, cancel sprint and go prepaid with the stylo till a phone comes out that i feel is worth paying 800+ for.
    10-12-2016 01:11 AM
  19. D13H4RD2L1V3's Avatar
    The Note has always used a Wacom digitizer. The S Pen relies on Wacom tech for it to work.
    Only the Note and some Samsung tablets that feature an S Pen have a Wacom digitizer. None of Samsung's other devices feature a Wacom digitizer.
    The LG Stylo uses a conventional capacitive stylus but the Microsoft Surface also uses a Wacom digitizer.
    10-12-2016 09:51 AM
  20. amyf27's Avatar
    When I had the s7edge for a short time, I was able to screen capture and go into edit mode (stock app) then write with my finger. There are pens you can purchase to use with the s7edge and other touch screen type phones. Most have a soft rounded tip.
    10-12-2016 10:08 AM
  21. PRGDR's Avatar
    Yes, I have tried S-pens form previous notes on different android phones and tablets and they do not work.
    10-12-2016 03:32 PM
  22. rusty502's Avatar
    ........Samsung uses Wacom, correct.....and the S pen will only work on a device with a Wacom digitizer.....Microsoft uses Ntrig, which is a similar technology, but not the same.....just the Samsung Note series ( including the Note 10.1 tablet ) or a Wacom compatible tablet/sketch pad can use the S pen.
    Sent from mTalk
    10-12-2016 03:49 PM
  23. Momof9Blessings's Avatar
    The Intuos Creative Stylus 2 pen DOES WORK on the S7 Edge. It will open apps, type etc.... At Best Buy she even used it to write on a photo. I saw that there is an app that will give you a keyboard option to do handwriting too....
    It does use bluetooth....
    10-12-2016 05:11 PM
  24. Kilroy672's Avatar
    What are the chances that Samsung will do a full software update with a bunch of Note 7 features any time soon? I would like to see Note 7 OSD for one, updated touchwiz, secure folder and Samsung notes would be nice. Feel free to add your choices.
    10-12-2016 08:22 PM
  25. Morty2264's Avatar
    This would be really interesting and would certainly help Samsung. However, I don't know about its chances of happening. But, I'm sure Samsung will do whatever it can to get itself back in top after what has happened. Who knows what they will do - it will be exciting to see what happens!
    skatergirl likes this.
    10-12-2016 08:32 PM
34 12
  1. Note 7 Contract Question
    By Bartone in forum Samsung Galaxy Note 7
    Last Post: 10-13-2016, 02:52 PM
  2. Replies: 45
    Last Post: 10-13-2016, 08:33 AM
  3. Huawei P9- model EVA-L09 is not compatible with Android Auto
    Last Post: 10-13-2016, 03:15 AM
  4. Replies: 1
    Last Post: 10-12-2016, 10:16 PM
  5. I am using A S6 edge. Will my text messages safe to Send?
    Last Post: 10-12-2016, 10:03 PM
